Question about Lavazza Espresso Point Capsule Machine
My machine will no steam! It purges when I press the steam but nothing happens?
  • c_lax Sep 20, 2010
    Great advise! It worked thanks!
  • 1,711 Answers
There are two most possible problems.
Fist the steam wand have clogged from dry milk. So you try soaking the wand in boiling water and after some minutes try the steam again. If you hear any steam out just keep it open and the steam will clean the rest. If you don't hear any steam you can help it by inserting a thing paper clip all the way in the wand and try again soaking and steam.
If you don't have any result then the steam valve is goggled from a scale deposit and you need to try a couple of times descaling and you have 85 % chances to open it. If not then you need to remove the steam valve and remove the scale deposit manually with the use of metal wire brush.
In any case give more emphasis in the first possibility with soaking.
Good luck
Usefull links
http://www.fixya.com/support/r4335301-descaling_espresso_machines_never_use
http://www.fixya.com/support/r5578817-fixing_traditional_home_espresso_coffee
Posted on Sep 14, 2010
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
Tip
Espresso machine will no steam, It purges when I press the steam but nothing...
Good luck
Usefull links
on Sep 15, 2010 | Coffee Makers & Espresso Machines
Hello, my saeco stratos is showing over heated in display everytime I take steam.Can this be solved?
Hi
When you are done steaming, just press the water button and open the steam valve again. This will purge the steam and cool the boiler back down. When it is cool enough the display will change back to "product ready for use". Have something under the steam wand as this is where the steam and water will come out.
May 11, 2011 | Saeco Stratos Coffee Maker, Espresso...
Hi, our Jura Impressa Xs90 keeps flashing 'fill system' & ' press steam'. There is plenty of water in it, we've tried removing the water and refilling. Doesn't work. If you press steam it just beeps...
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
May 02, 2011 | Jura Capresso Impressa X90 Espresso...
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
When i turn on the machine the "!" flash fast constantly and the "drop"light turn on; i turn the nob for the hot water but nothing comes out no water or steam...nothing works..i can hear the engine runnin...
It is telling to purge the air in the water line. Make sure there is no filter in the water tank and turn on the knob. The pump should **** the water and let it out from the steam arm.Hope it works.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
ERROR MESSAGE SAYS UNABLE TO CLEAN
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
Apr 30, 2010 | Brother DCP 115C All-In-One InkJet Printer
How do I clean printer drum. Printer is not working. Message on the display says to clean printer drum and to see manual. There's nothing in the manual on cleaning printer drumfor the MFC 240c all-in-one...
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Lavazza Espresso Point Capsule Machine Logo
463 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
