Question about Amana AEW3530DD Electric Single Oven
Oven made a loud noise, pop, and then black smoke....could heating element go out?
My oven is only about 3-4 years old and today I turned it on to preheat and once it hit 120 degrees it made a loud rattling noise then a pop and black smoke was coming out of the oven. Now the oven won't heat at all.
Sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
Posted on May 16, 2008
The things fecked throw it out the window
Posted on Jul 23, 2012
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
I was just preheating my GE JT950 oven and there was a loud "pop" sound from the top fan, and then smoke emanated from the oven. The circuit breaker in the home is fine, as no fuses were blown. Any advice
bake element do pop when they burn out and some will act like a sparkler and burn and burn .. I would look for a bad spot in the element of the oven that you wer heating . mm
Dec 03, 2009 | GE Profile JT952 Electric Double Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Oven fire, loud explosion sounding like a welding torch,flames. Very nervous!
Most likely an element burning out though it does sound a little more excessive than is the usual case. Was the fan oven on, in which case remoce the inner ear panel in the oven and check to see if the element surrounding the fan has burnt out
Oct 21, 2008 | Neff U1721 Double circotherm Electric Oven
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Open Questions:
Amana Convection Oven control pad problem Amana AEW3530DD Electric Single Oven Logo Popular issues: * turn * convection * turn off * View All » Related Topics: * turn * convection * turn off * View Less » * Print * Email * Flag This problem should be removed because: It's spam/self promotion It's in the wrong category It's irrelevant It's illegal It's inappropriate/offensive Other Reason: Problem with Amana AEW3530DD Electric Single Oven Amana Convection Oven - Beeping Continuously my amana convection oven, bought from sears, has continually started beeping. i've had to turn the power off because of this. it was doing it a few months back and then suddenly stopped; it has now restarted. Posted by avatarBetty Emadi on Aug 22, 2006 * + Add a Comment * Suggest a Solution 1. Add a Comment 2. * By avatarGuest Over a year ago * My Amana convection plus oven has started beeping and showing an F1 error. I have to turn off the range power to make it stop. This happened just after the warranty went off, earlier this year, and the repair place ordered a new circuit panel. By chance, I turned the power back on before they came to replace the panel, it had 'self corrected. It was fine for several months, now is beeping again. Anyone have a fix? Thanks. 3. Solutions (1) F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same.
Jan 23, 2012 | Amana AEW3530DD Electric Single Oven
1,690 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
