I'm sorry to hear that you're having trouble finding replacement water filters for your Cuisinart DCC-690 coffee maker.
After some research, it appears that the DCC-690 model does not have a specific water filter that is designed to fit it. However, Cuisinart does offer a universal water filter that can be used with any of their coffee makers.
The Cuisinart DCC-RWF replacement water filter is a universal filter that is compatible with all Cuisinart coffee makers that have a water filter. It is designed to remove impurities from tap water, such as chlorine, calcium, and other minerals, to improve the taste and quality of your coffee.
You should be able to find this filter on Cuisinart's website, or at a retailer that sells Cuisinart coffee makers and accessories. It is important to note that the filter should be replaced every 60 days, or after brewing 60 pots of coffee, whichever comes first.
I hope this helps!
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
