When we change the paper from front to back in my epson dfx 5000 plus impact printer the machine goes unresponsive the control p[anel doesnt respond and cant do anything after we switch the paper locations
    Genius:
  • 1,456 Answers
Hey there
check to see if the paper is fixed in properly into the tray
check that the printer is connected to the computer. The USB cable should be securely plugged into both the printer and the computer.
power cord is plugged securely into the printer and a working power outlet. Though this may seem like an obvious step, there are many instances when the printer is not working due to the power cord not being secure.
Posted on Sep 14, 2010
Error switching not completed pause
http://files.support.epson.com/pdf/dfx9k_/dfx9k_ug.pdf
Check page 23
There are 2 paper sources (front & rear) Switching between them has failed. I recommend you remove all paper from the printer, turn the power off and then back on again. Reinstall the front paper and test printing. Then install the rear paper and test.
Aug 28, 2013 | Epson DFX-9000 Matrix Printer
My DFX 8000 Printer head is moving, but it is not printing, ribbon and head is OK. i change the head and ribbon but problem is same.
Thanks, I Try it. but it is still not printing, because printer head pins
are not coming to the paper. Head pins printing sound is coming.
thanks
Aug 13, 2013 | Epson DFX 8000 Matrix Printer
Error 13 on epson dfx 9000 printer
Hi Good day!!
Error 13 is a printer error code that signifies that there is a paper jam. You need to check the jam in the entry if your system shows this error. Error 13 also indicates the need to replace the pickup roller in the printer.
Aug 29, 2012 | Epson DFX-9000 Matrix Printer
Wants to know if Epson DFX 9000 and LQ2180 printers can have network cards in them to be used as network printers?
If it is Epson DFX9000n then it has a network card however you can share the DFX 9000 without a network card through a computer as a host machine.
Aug 05, 2011 | Epson DFX-9000 Dot Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Reset Epson DFX-8500 Matrix Printer
Remove power cord for at least 10 seconds AND delete print job manually from Windows(?) Open Control Panel>Admin Tools> Services. Stop print spooler service. Delete contents of c:\windows\system32\spool\printers folder, restart print spooler service, plug printer back in.
Aug 14, 2009 | Epson DFX-8500 Matrix Printer
E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Oct 15, 2008 | Epson DFX-8500 Matrix Printer
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
Error code 14
Error 14 hccp sensor malfunction- Its the sensor for detecting paper if its coming from the rear or front.
Chances are if you are getting the error even when your paper and setting is set correctly, you will have to call servicer or Epson so that if its within the warranty they will have if fix for free.
Pls dont forget to rate solution, thanks!!
Apr 29, 2008 | Epson DFX-9000 Matrix Printer
27 people viewed this question
k24674
jasbo
jasbo
