Question about Audiovox FPE4216P 42 in. Plasma HDTV
Power Problem I have a brand new Audiovox Plasma TV. The TV turns on then it shuts off on its own. It was working for a while but now I can't get it to stay on more than 1-2 minutes before it shuts down.
Sound no picture and red dot/sparkles/speckles fix summary
This post is basically for anyone that stumbles across it trying to fix what seems like two fairly common problems with plasma tvs. I apologize for the length of it but hope it can help others.
To start off, I got a free Audiovox FPE4216P 42" Plasma TV.
The previous owner said that there was a red cloud in the top center that after time spread across the top and down the center of the screen. Some time later, they were watching it and it was as if someone simply turned the power off. After that, there was no longer any picture - menu or otherwise.
After much research on the net, it seems that fixing plasma TVs is strongly based on the educational guess method. This compounded by the fact that replacement parts are quite scarce and generally crappy customer service provided by the manufacturer if the TV is older than 14 months basically makes many of these TVs $2000 doorstops if something goes wrong with them. Luckily, my TV uses many LG boards which seem to be used in a number of different makes and models.
NO DISPLAY ISSUE:
Once I took the set apart, I first checked the power coming into it and it checked out ok. I then found a fuse on the YSUS board that had blown, upon replacing it, I no longer had sound. The indicator light on the front would turn from red to blue for about 3 min then back to red. After this happened, the LED on the power board would light up and the there was no longer any response from the power button (led on front would only stay red). I would have to unplug the set and plug it back in to duplicate the above.
I then checked the voltages for Vs, Va and 5v on the connectors coming off the power board (using the DC setting on a voltmeter) against the specs on the sticker on the back of the display panel and they checked out.
It was recommended that I change the YSUS board since the fuse had blown on that board. This seemed counter-intuitive to me since it seemed that the power was fed into the YSUS board through that fuse first as if to protect the YSUS board.
With reluctance, I purchased a "new" YSUS board. Once I popped it in - presto! I had picture! But picture with a cloudy, sparkly red "I" beam that would show through the dark areas of images including the menu screens. It seemed that as long as there was a color over where the "I" beam ran, it was fine and there was only a problem when the image was supposed to be black.
RED DOTS - SPARKLES - SPECKLES - and possibly MAL DISCHARGE ISSUE:
I say possibly mal discharge because it seems that some label this problem as such where some describe mal discharge as another problem.
After much research on the net (again), it seems that there are two fixes for this problem: 1 - a new control board and 2 - adjusting the voltages. It seems that each fix has about a 30 - 50% success rate. With the first fix, you just pop in a new board and you could be done or you could have the same problem. With the second fix, people have said that the dots have gone but the image is now crappy or they have different color dots. Some also say that merely changing voltages will only temporarily fix it. I opted for the cheaper second fix.
My power board has two potentiometers (pots) on it (adjustable dial thingies). One for the Vs and one for the Va. I first made sure that these were adjusted to spec. I took readings off of the molex connector and grounded to the support bracket of the set.
My YSUS board has 4 pots, two are labeled SetUp and SetDn and the other two are on little circuit boards rising off the YSUS board - one of which was completely inaccessible due to it's position behind the support bracket.
I first set the TV to an empty input since the red showed best against all black. Jacking up the SetUp pot seemed to have the effect of making the black really black and essentially removing the red. SetDn didn't seem to due much and I didn't mess with the other pots. When I switched to an active source everything looked great but then I started to notice that on bright images that weren't quite white, there was blotchy pixelation and redness. It then started messing with all three accessible pots and got the image to be really good but I could still see some red and now blue sparkles in the dark areas.
I was pretty satisfied with my results but there was that one other pot that I could not get to unless I removed the YSUS board. Since I knew I would have to adjust that pot multiple times, I decided to remove the board and drill a small hole in the support bracket to gain access to the pot with the board installed. For me, this was the most difficult and frightening part. I didn't want to damage the panel itself and I also didn't want to get metal shavings everywhere. I carefully masked off the area and nearby boards with paper and when I drilled I held a piece of wood behind the bracket.
I then had access to all 4 pots and just kept messing with different balances between them. I used an empty input to check the black and numerous DVD's to look for crappy picture on lighter areas. As it turns out, the menu for the Underdog DVD really showed the light image flaws.
Now, the image is about 98% perfect. When a lighter image turns to complete black, there are some, extremely diffuse red and blue brief pixel flashes (just for a millisecond) but then the black stays black. To notice it, you have to be within 3 or 4 feet of the TV which I think is too close anyway for a 42" TV and is virtually non-existent when watching DVDs.
Here is some extra part number info with possible equivalents:
YSUS: 6871QYH953A or 6870qyh005B and possibly 6871QYH053B EAX31974801 EBR31872801 EBR32642701 6870QYH105B EAX31631001 EBR32642702 1032298-hs
Control Board: 6871qch977b or 6870qch0C6b and possibly 6870qch006b 6871QCH077B 5070-5623
Power Supply Board: 667-PH42FB6-20 or 782-PH42D8-200a and possibly 6FB0192010
Posted on Jun 21, 2008
Plasma tv shuts off randomly
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 04, 2016 | LG 60PN5300 60" Plasma TV 1920x1080, 600...
Broken screen on audiovox fpe4207hr
At 42", it will be cheaper to by a new tv. Plasma is vacuum sealed. The new LED is better.
Feb 12, 2014 | Audiovox FPE4216P 42 in. Plasma HDTV
Audiovox KLV3913 TV/DVD dead
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 06, 2017 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
NEED A AC POWER ADAPTER
Had same problem. Found brand new power supply that is original part from website below:
http://www.encompassparts.com/products/?PWW302-AD13D-03
It was about $100 w/ shipping. Took about 4 days to receive. TV works again!!
May 28, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox FPE4216P won't come on - power board problem?
My set is 14 mo old and yesterday while on it suddenly switched off. buttons did not work to turn it on again though the red power light was on. I unplugged it and replugged it and it then turned on. The picture is there but its fadded and has areas of black pixalation in it. It's over warrenty and I just don't know what to do. What happened and will it cost over $500 as a repair shop told me on the phone? This was a gift to me and I'm on Social Security so I'm kind of shaken by this.
Thanx, Lee
May 19, 2008 | Audiovox FPE4216P 42 in. Plasma HDTV
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Audiovox FPE4216P 42 in. Plasma HDTV Logo
457 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
