Question about Polaris Polaris Halcyon Booster Pump - Pb460q
Little black disc has piece sheered off. Cannot pump water as wheels cannot turn. In FRance but approved dealer said would have to buy new pump if black disc irreparable. Can spares for this be supplied? It doesn't matter if you can only supply to dealers, but I can at least get him to contact you.
  • 2,299 Answers
I'm sorry to tell you, but no I don't have any way to get just the parts. You have to replace the pump! Sorry I couldn't help you!
Posted on Sep 14, 2010
Winterize vcross 365 fifth wheel
I think you have posted this several times so I wanted to add this.
The best thing is to have a dealer do it. You need to know if you have by-pass kits installed, depending on what you have for storage tanks they need to be drained, RV non-toxic anti-freeze needs to be added to plumbing and flushed through, water lines should be blown out along with draining so if there is a place where the water was level it gets forced out.
Here is a quick info for a skyline, but it really depends on what you have for plumbing.
Purchase 4-6 gallons of RV approved, non-toxic anti-freeze.
2. Drain all tanks, fresh water and sewage tanks.
3. Turn water heater by-pass valves to by-pass position. (The by pass valves are located near the
water heater incoming lines - an access panel may have to be removed depending upon the
model.)
4. Drain water heater.
5. If installed, remove water filter from assembly and discard. Install diverter if included.
6. Pour an amount of RV non-toxic anti-freeze into the fresh water tank to fill the tank above
minimum water pump operating level. (Use of a long funnel may be helpful) Add more, if
necessary, during procedure.
7. Turn on pump switch and open the cold water side of all faucet fixtures. Leave open until the
anti-freeze comes out (generally, pink in color). Repeat for hot water side.
8. Flush toilet until anti-freeze begins to flow into the bowl and then pour one gallon of anti-freeze
down the toilet to winterize the black tank.
9. Pour anti-freeze down each shower/tub, lavatory sink, and kitchen sink to fill p-traps.
10. To winterize gray tank(s) pour one gallon down each related sink drain.
*****Now the best thing is to post a new post and see if someone has your manual to be exact.
But if you get no response, and refuse to let a dealer do it, you have a little bit of info to help you.
Sorry I couldn't find the exact method for your model.
Apr 09, 2013 | Sport & Outdoor - Others
Coolant Resevoir Tank Leak
A repair might buy a little time but you should replace.Either the junk yard or dealer will have this part.it is a coolant resevoir.
Aug 28, 2012 | 2002 Chrysler Sebring
How to replace lower rad hose
drain the radiator, there is a petcock on the side/bottom it is plastic tee-handled shaped. then remove the two hose clamps one on the radiator the other on the engine( best with a socket mine are 5/16 inch). Hope this helps Tim.
Note: putting on ramps or jacking up and using approved jack stands gives plenty of workspace
May 28, 2011 | 2005 Dodge Caravan
2004 Pontiac Grand Prix overheated on the way home from work - had it towed. Water coming from a small black hard plastic line just behind the surpentine tension wheel that looks like it comes from the top...
This was an easy fix take about an hour.
There are 2 black elbows made from same material ashtrays were made from.
You need to remove the belt tensioner--parts is dealer and cost under $20.
Just have to make sure you don't break off pieces into the block.
May 10, 2011 | 2004 Pontiac Grand Prix
I have a 1997 isuzu rodeo. 2wd. the front left wheel hub has sheered off 3 of the lugs. do I need to replace the entire wheel hub or can the lugs be replaced? If so how.
Depends if the studs are pressed in or an as built unit. Have a look at what the stud looks like and if it appears to have little grooves in the back side, you can hammer out the other 2 and then replace. I would also look into why the studs are having that much force that they are being sheered off.
Mar 14, 2011 | 1996 Isuzu Rodeo
Serpentine belt blew due to belt wheel sheering off
with the belt off,try to spin each and every pulley,and water pump,alternator,idler pulley,automatic belt tensioner pulley,sounds like one froze up and took the belt out.
Dec 10, 2009 | 2004 Toyota Corolla
Primed my shallow well pump---started okay--
sometimes pipe will scale over time depending on the water chemistry.
You can use PVC pipe indoors where your water enters the house.
May 06, 2009 | Flotec Corrosion Resistant Shallow Well...
The lamp on my Samsung HLP5085 burned out last night with a loud pop. I followed online instructions to remove it and orderd a new lamp. Then, I noticed that a small 1"x1" piece of glass...
It's doubtful that buying a new color wheel will solve that cracked glass problem. However, if you are going to buy a new color wheel you may as well purchase a new television as they are extremely expensive and most new units do not use them. I suspect the piece of glass may be protecting the lamp from anything on the inside of the TV or preventing anything from getting to the color wheel so it may work out just fine the way it is. I would suggest reporting back after you have replaced the bulb. In other words, don't order anything else just yet.
May 06, 2008 | Televison & Video
XL30 Hi temp. Two problems: 1) Hi temp booster not working...worked on and off for awhile, now won't get up to 180. 2) Turned on today and water flooded out. Water overfilled machine, turned off and...
To attempt to solve the over filling, clean the probes in the back right corner. Use a green scrubby pad.
There is also two probes under the front screen. Clean them too.
As far as the booster not working, there could be many reasons. One of the few things that you can attempt is resetting the hi-limit. Turn off the breaker. Remove the bottom panel. Look to the right side. Look for a black mushroom platic piece with a little button in the middle. It will click if it was tripped.
Some booster use a disc type of hi-limit. These type are a little stainless and plastic barrel. There is a red button between two electrical connectors. It will click also.
Good luck - Mike
Mar 14, 2008 | Dishwashers
Polaris Polaris Halcyon Booster Pump - Pb460q Logo
21 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
