Question about Sylvania CL772B 17" Flat Panel LCD Monitor
Flashing green power button
The monitor is not coming on, but has a flashing green power button
  • T Bodkin Jul 20, 2008
    I have the same problem with a sylvania model 568. I removed the rear cover and screws holding the circuit boards. When the power is connected and video source attached I remove the larger of the two ribbon cables. The backlight then illuminates and when the ribbon cable is replaced I have video until the video source is removed. I am unable to locate a schematic to troubleshoot this. any suggestions would be appreciated.
  • robert_adams May 11, 2010
    I had the same problem with a dell monitor. the problem with that one was The transistors on the back lite inverter board. I don't know if this helps or not. Just a thought.
The monitor green light comes on but the monitor itself does not come on. Sylvania LCD CL722b-Model 780
Posted on May 20, 2009
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Problem with my lcd monitor where it won't show ... Optiquest Q22wb computer monitor won't come on - power button flashes green then off - power is...
The power supply in the monitor is probably broken. Take it to a repair shop or purchase a new one. LCD monitors have become very inexpensive these days.
Dec 25, 2009 | Acer X203H bd Monitor
Falshing green power biutoon.
Verify all cables are secure, try reseating them. If the power led continues to flash, this usually means the power supply in the monitor is bad.
Oct 03, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power button keeps flashing green
This could be your power supply unit malfunctioning. Replacing the power supply may fix this problem.
Mar 26, 2009 | Compaq Presario 700 470024-192 Notebook
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Mo picture on monitor
I had the same problem. power led would flash green for a few minutes then the monitor might come to live. the problem was multiple bad G-LUXON capacitors on the power supply board and inverter. the monitor is full of them. just search online for bad caps and they are near the top of the list. replaced them and it came back to life.
Jan 24, 2008 | Northgate MONNG7NSS 17" Flat Panel LCD...
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Sylvania CL772B 17" Flat Panel LCD Monitor Logo
840 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
