Question about Watches
I do not know how to use a TCM watch, serial Nr. 214612. Can i have some asistance?
Is This a genuine Tag Heuer watch Serial number 70076507
How would one know from the serial number. Numbers are easier to copy than even watches!
Oct 01, 2014 | Tag Heuer Link Watches
Cartier serial number550740MX
I have access to a Watch CSA Counterfeit Busters subscription and the serial number does not come up as a reported counterfeit.
Oct 12, 2013 | Cartier Pasha Seatimer Mens Watch W31088U2
I'm looking for the manual instructions for my LANCASTER Watch 0346 I dont know how to adjust the date or knows about it
Pull out to the "winder" to the first click. this is to change the date. The second click is to change the time.
Changing the date - rotating the winder (if you were looking at it) in a clockwise directions changes the major decimal - the number on the left e.g. 0, 1, 2, 3. Rotating anticlockwise changes the lesser decimal - the number on the right e.g. 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Hope that helps.
Jun 01, 2011 | Lancaster Lanza Gold and Dial OLA0346YG/NR...
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 | Watches
I have a TCM radio controlled mans watch , I have replaced the battery now I cant put the watch at the right time can you help please
Sep 13, 2010 | Watches
I have a movado watch given to me by my grandmother I want to know if you could help me tell if it is real or not or if there is somewhere I could look up the serial number or tell which of the two numbers...
mcdevito75 here, Without seeing the watch, it"s hard to tell, the serial number that counts is on the movement itself, not the back of the caseing. See a small watch repair shop in your area for advise.
Jun 25, 2010 | Watches
Where ca I buy A new stainless steel strap and pins for my tcm chronograph quartz 20 bar watch serial number 234245
As long as it's not a strap exclusive to your watch, you should be able to take it to any jeweler who sells watches or a watch selling kiosk in a mall. I wouldn't take it to a store like Wal-Mart, just because they have no requirements for their employee's to know a crown from a clasp, for them to work in the jewelry area.
Jun 22, 2010 | Watches
WHERE CAN I BUY A NEW STRAP AND PINS FOT A TCM
mcdevito75 here, Any small watch repair shop in your area could help out.
Is my watch authentic?
no need for serial number- look on the dial, if the 'x' marking the ten o'clock has 'cartier' written on it, your watch should most definately be authentic.
Jun 13, 2008 | Cartier Tank Francaise W51001Q3 Wrist...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
