Question about Xerox CopyCentre C128 Black and White Copier
How to clear fault 116-365 - Xerox CopyCentre C128 Black and White Copier
My Mitsubishi colt automatic car runs fine but light comes on fault code 1867 I cleared fault but as soon as you switch off engine and back on again the light stays on again
How did you clear the fault? By using a code reader and clearing it or by disconnecting the battery? That only erased the fault from the ECM memory. That fault code is specific to Mitsubishis, so I have no idea what it means. But if the problem that set the code originally has not been corrected, it will set the code (and turn on the light) as soon as you try to use the car again.
Feb 11, 2017 | Mitsubishi Colt Cars & Trucks
WHAT IS THE MEANING OF CODE D16?
(D16) Gen 2 Card Reader Communication Fault This fault occurs when the control has not received a health check function from the Gen 2 debit card reader in 30-seconds. If this fault occurs in Ready or Vending Modes, the control will log the fault and display "OUT OF ORDER". Once the control enters READY Mode and the fault has not been corrected or cleared, the control will display "OUT OF ORDER". The fault is self clearing; therefore, once communication is reestablished, the control will clear the OUT OF ORDER condition and allow full dryer functionality again.
Dec 20, 2015 | Maytag MDG16PD Gas Commercial Dryer
Error f19
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
May 04, 2014 | LG LWD3081ST Electric Double Oven
This Greg thanks . how do I clear the code?
Clearing Codes
Print
Stored faults should only be cleared by use of the DRB-II or similar scan tool. Disconnecting the battery will clear codes but is not recommended as doing so will also clear all other memories on the vehicle and may affect driveability. Unplugging the PCM connector will also clear codes, but on newer models it may store a power loss code and will affect driveability until the vehicle is driven and the PCM can relearn its driveability memory.
The -ERASE- screen will appear when ATM is pressed at the end of the stored faults. Select the desired action from ERASE or DON'T ERASE. If ERASE is chosen, the display asks ARE YOU SURE- Pressing ENTER erases stored faults and displays the message FAULTS ERASED. After the faults are erased, press ATM to return the FUEL/IGN MENU.
Sep 29, 2013 | 1993 Jeep Grand Cherokee
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
Print error 09, 005, 40:5069 how do i fix this?
Hi
This error in Xerox 8560 printer occurs when Cyan ink melt heater is on but the ink is not dripping. To troubleshoot this issue please make sure that you are using genuine Xerox ink. If yes then run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu.
Also check for broken or wrong type of ink sticks. After this try clearing the fault by running Clear ISC Fault option. If the sticks are also fine then run the appropriate Ink Melt (1,2,3,4) Heater test. If the test fails then there is an issue with the print head.
Daniel Scott
Jun 08, 2010 | Xerox Phaser 8560MFP Laser Printer
Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Jul 02, 2009 | Kodak Office Equipment & Supplies
Oven does not work f3 in the screen
Oven control beeps and displays any F code
error (for example F11).
Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/
OFF and call your dealer or authorized service agent for assistance.
Dec 17, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Xerox CopyCentre C128 Black and White Copier Logo
975 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
