FixYa.com
Tags:
System Power Supplies
Generic problem for all System Power Supplies
Bestec ATX-250-12E problems
posted by Tre_rules on May 16, 2008
My power supply's fan doesn't run. It starts, makes a wierd clicking sound, and stops. Is this why it shuts off during games and other things? Can you tell me (in detail since I'm no computer genius) what to do???
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 24, 2008
Not Rated (0)
DCSH
Rank:Wiz Wiz
Rating: 82%, 35 votes
Hi the power supply fan is jammed because of some object stuck - this could be some broken plastic component of the fan or the protection grill could be jamming it . Do not switch your comp before checking this out because inadequate or no air cooling can damage your computer .In Power off condition with a small screw driver try rotating the fan manually or by blowing air into the fan , it should spin smoothly else your power supply to be replaced .
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP (327477-B21) (327477b21) 225-Watt Power Supply HP (351599-001) (351599001) 460-Watt Power Supply HP (5187-1098) ( 5187-1098 ) Power Supply HP (0950-2999) (09502999) 160-Watt Power Supply HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply HP Compaq 175-Watt Power Supply HP (122641-001) (122641001) Power Supply
Can you Help with these System Power Supplies problems?
XION (XON-500F8X2-201) (XON-500F8X2-201)...
Pc stoopped working, replaces...
Originally built PC with Xion... Answer This...
Dell POWER SUPPLY PS-5201-5D (PS52015D) Power...
Latitude D505
Just bought new charger so the... Answer This...
Jeep Patriot turn signals
Hi, I just bought a 2008 jeep... Answer This...
MY SONY LAPTOP WONT BOOT
my sony laptop turns on, i see... Answer This...
electronics design
how to design unregulated power... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
