Question about SanDisk Sansa Clip MP3 Player
Sansa clip I can listen to music, but I have no display. Is the a fix for this?
  • Debbie123 May 30, 2008
    chop sewet had to redo my hard drive on pc too
  • Rob_Swift Nov 05, 2008
    I have this same problem. Fortunately I memorized the menus before the screen went out completely. This is what I get now during the Sandisk logo before it's black again.
    Resets, formats, reflashes they all failed.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
I cant put music on my sansa clip becase it says its full
If you have too many songs on the player delete some of the ones you don't listen too or convert the files to a lower bit rate and it will allow more songs, but at the cost of quality.
Jul 05, 2014 | SanDisk Sansa Clip MP3 Player
Am getting very frustrated with my Sansa Clip. I download a podcast or music onto my Clip, yet the Clip tells me that the folder is empty, but when i plug it into my computer again, all the downloads are...
what is the size of the podcast mp3? Many podcasts don't actually send you an mp3 of the podcast, but a link embedded in the mp3 that streams the podcast to your player of choice. (twit does this, fairly frustrating) if the mp3 is not very large, that is probably why.
Mar 06, 2011 | SanDisk Sansa Clip MP3 Player
I have a message on my sansa clip that I want to get rid of so that I can continue to listen to my book. I can't listen till this is straightened out. It says synchronize to continue your music...
Audible books are protected, you can copy them into device, but you can't play them (...subscription...appearing ). You must use audible manager to sync audible books.
You should delete audible books that make pop up a message " synchronize to....", otherwise, your device always pops up the message when it meet the audible books.
Apr 06, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip doesn't show any music even when I plug it into the computer. What do I do?
I managed to fix my Sansa Clip by taking it apart and following these steps:
http://www.bitofexperience.com/home/miscellaneous/repairs/repair-sansa-clip
Nov 08, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
"No Music"
Either:
1)The licenses on the songs expired, which means you will have to update them through the music service that you acquired them from. (Not likely since the ripped songs are doing the same thing - although you could have inadvertently checked the option in Windows Media Player to add a DRM license to them).
Or:
2) Switch the USB Mode in the Settings menu of your Sansa clip to Auto-Detect or MTP.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Not enough space for music db Please free 30 MG
Had this same problem. You need to lock turn off the player. put it into the locked mode and hold down the middle button before plugging it in. Then back up and reformat.
Detailed instructions I found were here:
Frozen sansa clip
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Unable to play all songs downloaded on sansa clip
You have to resyhnchroize within Rhapsody itself to make the message go away.
Oct 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip; Does not appear on icons
unplug Sansa MP3 player from your PC, go to menu ->settings, scroll down to USB-Mode, change mode from MTP to MSC, re-connect, yout PC will connect, detect new usb devive, disk drive.... and your sansa icon will be displayed at computer folder.
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
112 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
