Question about Sharp Microwave Ovens
Microwave problem. The type on the control panel has worn off. Is there a replacement decal available? If not, what do I do?
  • Sharp Master
  • 17,130 Answers
One option is to get slef adhesive plastic stickers made in the same format and stuck on top of the pad.
This must be enough to get the microwave going or some more time.
Posted on Sep 14, 2010
Microwave decal replacement
Fixya does not sell replacement decals.
Jul 22, 2017 | GE Microwave Ovens
Can you buy replacement decals to show the button functions, as ours have worn off. Thanks in advance.
'Decals' are not available separately.
You can order a replacement keypad here ... http://www.searspartsdirect.com/model-part/r24gt/0958/0123242/p0102289/00001.html
$90.00+ & you'll need to dis-assemble the microwave to replace this part. Probably less expensive to replace the oven.
Aug 23, 2015 | Sharp R-24ST Microwave Oven
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Microwave makes beeping noises and comes off and on by itself
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you probably have a failed membrane keypad.
Is it possible that some spray cleaner or steam accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Also be sure your filters are cleaned, or in the case of charcoal types, replaced.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
But please note that for some models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself
job.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 26, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
This is a built in microwave with a push button to open the door. Push button won't work and door won't open.
It may be a broken door open lever or a worn or broken door open button.
If it's an owner the range type, you can likely get to and replace the door latch parts by just removing the control panel assembly.
If it's a counter top unit, you will need to remove the outer cover to get to the door latching parts.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Dec 25, 2009 | Whirlpool Microwave Ovens
HOW DO YOU REPLACE MEGATRON IN GE SPACESAVER 1400 MICROWAVE
We have a service manual which covers many of these type microwaves and have uploaded it them to our site here to help you.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 11, 2009 | Hotpoint RVM1635 Microwave Oven
The numbers are worn off. Can we just replace the
yes you can its called a membrame switch but you will need to take the facia off and connect it to the main control pcb so you need to find the spare part first not all are available as spares
Oct 01, 2009 | Panasonic NN-T964SF Microwave Oven
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
