Question about Car Audio & Video
Saturn L300 2004 car radio without harness connecting a new radio without harness
3 Suggested Answers
SOURCE: I need to know which factory wires are hot and ground so I can install a new radio without a wiring harness
what you are going to need is the wiring diagram... either car manual might have it or a local car audio place might have it... obviously the charge you for it... usualy for newr cars you can find it for free just by researching it on google... i found this for you duno if it helps... just code the wires and cut them to make your new bridge to the unit without a harnest
Have fun
goodluck
1991 Chevrolet Caprice Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Apr 28, 2009
Daveatwhips
  • 492 Answers
SOURCE: 2005 chevy cavalier after market
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Posted on Sep 03, 2011
I have a 1995 saturn sl1. And i took out my factory radio and Will be putting in a JVC KW-AV50 stereo. My question is, how the hell to i wire the jvc up?
Get an aftermarket harness and dash kit for your car. Harness plugs into existing factory harness. Color coded for radio.
Nov 11, 2017 | JVC Car Audio & Video
New radio, new amp...still no sound from radio in 2007 Saturn vue...what's wrong?
Without testing your guess is as good anyones on here . New radio - new amp ? Factory or aftermarket ? Is there B+ voltage to the radio , and does it have good ground .
Jan 22, 2017 | 2007 Saturn Vue
Having trouble with an aftermarket radio hrness in a 2001 saturn sl it wont turn on what can i do
the only 2 wires you dont want to cross are red and black . once you have red from radio red from harness, black from radio black from harness connected it should light up ..the speaker wires can be "trial and error" . if red and black together dosent light it up check the fuse on the radio and on incoming red wire. try bringing 2 wires straight from the battery with a fuse between the red one to radio,if it dosent light up then with "direct power " then the radio needs to come apart to see ether internal fuse or burnt our circuit. ps: sometimes you only need to connect the red "live" wire and touch the black on the casing of the radio to test for life.
May 01, 2015 | 2001 Saturn SL
How easy is it to install a new cd player
if you work in a stereo store it is a snap, otherwise you are taking on a task. the bay is made to receive only a saturn OEM radio and plugs into a GM wiring connector. So you first have to have on hand an adapter to put a standard sized radio into that saturn curved top bay and a wiring adapter to connect your new radio to the GM wiring harness. You can find both items on eBay.
Jan 28, 2011 | 1998 Saturn SL
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
I need help installing a new radio.
Hi my names Josh and yes you will need a harness if you havent allready purchased one. Plugging your new harness in is very easy and from there you just follow the colors from the new harness to the colors on the harness wires coming out of the new car stereo reciver Red with red yellow with yellow black with black. white with white gray with gray make sure you pay attention to the white and gray wires they are marked one with stirp and one without one you want to put white with stirp toegether with the white with stip on your harness like wise with your green and your purple
Mar 02, 2010 | Buck Saturn Sc1 Sc2 1996 1997 Radio...
Car audio
Here are the wire colors and what they do in the system. Please rate my help.
1994 Saturn SL Car Radio Stereo Wiring Diagram
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Jun 16, 2009 | 1994 Saturn Sl
Wiring diagram
Battery GREEN/BLACK (+) RADIO HARNESS
Accesory BLACK/PINK (+) RADIO HARNESS
Ground BLACK/GREEN (-) RADIO HARNESS
LF Speaker (+) ORANGE/GREEN
LF Speaker (-) BLUE/WHITE
RF Speaker (+) TAN/GREEN
RF Speaker (-) GREEN/ORANGE
LR Speaker (+) GRAY/BLUE
LR Speaker (-) BROWN/YELLOW
RR Speaker (+) BLACK/VIOLET
RR Speaker (-) ORANGE/VIOLET
Jun 16, 2008 | 1995 Saturn Sc
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
