Question about Texas Instruments TI-84 Plus Calculator
My texas TI 84 starts but the cursor doesn't flash and the calculator doesn't react at any button ( only on works). What do I have to do?
  • roelvdv94 Sep 14, 2010
    I tried that but it isn't helping... my screen is still empty ( not black) and it doesn't react at anything. Even if I try to close the calculator it doesn't do anything..
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't do it, please reply to this post and we'll go on from there.
Posted on Sep 14, 2010
Why is my calculator frozen?
Is the cursor checkered? If so, there is no more space on the entry line. Use the DEL key to shorten it or clear it. Clear the RAM also.
Jul 19, 2014 | Texas Instruments TI-84 Plus Silver...
My TI-84 cursor will not allow me to type anything
If the cursor is not allowing you to type anything that means either the calculator available memory is full or that you have exceeded the number of characters in a single command.
Clear calculator memory or just clear all entries (history) or split a complicated command into multiple shorter commands.
Nov 21, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 calculator isn't working. When I press the "ON" button, sometimes it would respond, but most of the time it doesn't. The screen just remains blank. I've changed my batteries...
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 09, 2011 | Texas Instruments TI-84 Plus Calculator
My ti-84 calculator wont react to anything and it says garbage collecting. i think the bar on the side should move and its not moving and its been like this for several weeks. i did download a whole pile...
I remember this happening once to my TI-83. I know it's a different calculator. But it happened frequently. Without completely reconfiguring the calculator, you can remove the batteries whenever you see the message and when you start it up again, it should be okay. It may continue to display this message once in a while. I used to just remove the batteries. I don't know if it will work on your TI-84 the way it worked on my TI-83, but I hope this helped!
Please rate my solution!
- Frankie
May 05, 2011 | Texas Instruments TI-84 Plus Calculator
My calculator is completely non responsive. When I hit the on button, the calculator cursor comes up but does not blink or allow me to type anything in. I have to hold the on button to keep the cursor...
It sounds as if the batteries are dead. If you are having to hold the power button on to keep the cursor on the screen, that is because the batteries only have enough power to flash a cursor, holding the power key means that the flash is constant. Try changing the batteries, this should solve the problem.
Apr 27, 2011 | Texas Instruments TI-84 Plus Calculator
Ti-84 plus, calculator is frozen with just a flashing cursor, no key operations work. Batteries were corroded, but calculator has brand new batteries now, and problem still persists. Would resetting it...
its possible that the batteries leaked inside and cause some problem.
you can try to reset but only if you can connect the Calculator to the computer because the keypad is not working
if you want to fix the Calculator let me know
ecrdn@yahoo.com
Jack
Oct 18, 2010 | Texas Instruments TI-84 Plus Calculator
Press
Have you tried to reset the calculator?
From page 671 of the TI-84 Guidebook:
To reset the calculator:
1) Remove all AAA batteries
2) Hold down the On button for 10 seconds
3) Reinsert AAA batteries
4) Turn the calculator back on.
Note: When you reset your graphing calculator, the contrast sometimes changes.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
Unable to do anything - stuck on opening screen
I can turn the calculator on but can't use any other button. The cursor just keeps flashing.
Sep 08, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
Ti-84 Plus
Clean it with a bottle of compressed air
Dec 10, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
95 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
