Question about Health & Beauty
Sir, iam vivek gurung i dont know about anything about telly so i would like to work in telly. thank you.
3 Suggested Answers
  • 32 Answers
SOURCE: horn dosent work, dont know if iam missing
take a test light and hocke it up in wire for horn under car ground test light.have someone push horn if it does not light work your way back fuse horn button etc it allso a horn realy
Posted on Mar 28, 2010
barterjoe
  • 338 Answers
SOURCE: sir I ,VIVEK want to know how to read physics
This depends on the language you are best at reading. Many great physisists have come from Germany and Austria. You may want to look into the language that is best understood by you.
Special Therory is difficult enough to usderstand in your good language let alone a foreign one ;)
Good luck
Joe
Posted on Apr 08, 2011
LG 4200A
hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Jan 16, 2008 | LG 42LP1D 42 in. LCD HDTV
No sound
Hi are you sure the mute button isnt stuck on your controll if this is not the case then it could be on the circuit board.
Have you tried changing the sound mode and see if this changes anything.
The only thing you can do if it is a board problem is buy seperate speakers that will plug into the audio out put connectors doing this will let you know if it is a controll or setting problem also if you try external speakers then you would no that it isnt a controll problem if you got sound through the external speakers then the chances are that it is a solder problem if the solder had gone on one speaker you could eliminate that as you would know where to look but as it is both the speakers, Im basing it on that you are using the speakers inside the telly and not external ones if you are using extra speakers unplug them and just try the telly ones.
So basing it on that you are just using the internal speakers then it could be a solder problem on the board where the speakers plug into.
It could be something as simple as a resistor gone or going these are cheap to buy but i dont sugest fitting yourself unless you have relevant testing equipment and a good knowlege of soldering.
So first i would try changing sound modes on the telly if this dont change anything try pressing mute button just to make sure that the controll and all its functions are working properly.
But after this if it dont solve your problem then you could either buy external speakers as this might solve your problem but if you want the telly working as it should be you will need all equipment and to be able to read a spec sheet and be able to follow cicuit diagrams.
Let me know how you get on and what you want to do
Dec 01, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hi iam unable to login into the web interface can i knw the login id and password for it bcoz i forgot it nw finding it hard to reconfigure it plzzz help me!!!!!!!!
Hi Vivek,
I got your issue , if you have forgot the login id and password for ur router , its not possible to find the login id and password, instead you can reset ur router by finding the reset button on the router .u can just hold the reset button for 10 to 20 sec it will work.
Thanks & regards,
Prema.
Sep 30, 2010 | Proxim ORiNOCO BG-2000 (700003212) 802.11b
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
May 31, 2010 | RCA TruFlat 27F520T 27" TV
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
May 25, 2010 | Sony Playstation 3 (PS3) Console
Horn dosent work, dont know if iam missing anything i know the wires arent hooked up but tried and still nothing hooked horn to battery and it worked, i dont know if iam missing anythin from the steering...
Mar 27, 2010 | 1988 Chevrolet Camaro
In my laptap usb massstorage is not avilable,how it get.
my be a firewall issue and or a anti virus program interfering with the transmition between two 2 devices,
or look in controll panal in device manager look for anything that shouldnt be there like red or yellow marking green is okay
rod
Feb 03, 2009 | Intel D945GCCR Motherboard
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
