Question about Makita Garden
I need an instruction manual for the Makita Chain Saw DCS4610 my current one is in greek.
  • btmag4 Sep 21, 2010
    Thanks Jim
    I tried the address given but received the message Internet Explorer could not display this page.
    cheers
    malcolm
    ps I did not receive your posting 5 days ago but had this info from scott of the support group when I pointed out that I had not received any reply.
  • 1,041 Answers
This should do it:
http://www.makita.de/uploads/media/DCS4610.pdf
If you need something else, let me know.
Thanks,
Jim
Posted on Sep 14, 2010
  • Jim Parker
    Jim Parker Sep 17, 2010
    I messed up the first link I sent you.Copy and paste this one:
    http//www.makita.de/uploads/media/DCS4610.pdf
  • Jim Parker
    Jim Parker Sep 21, 2010
    If you take off the http:// on the first link I gave you, it should work. If not, here is another one you can copy and paste in the top address bar:
    www.makita.ca/data/upload/tools/DCS4610_owner_English.pdf
    The comment section doesn't allow me to give you a direct link. The solution section is the only place I can do that, and the system only allows one solution per expert.
    Jim
Makita 5012B 12'' Electric Chain Saw file size says it is part #744003-1. What is the equivalent in mm or inches for a metal file?
.325 chain takes a 3/16 file 91 chain takes a 5/32 file Check with your mower shop where you get your chain from
Oct 05, 2013 | Makita 5012B 12'' Electric Chain Saw
I am looking for an instruction manual for Makita Chop Saw 2414NB can you please help.
Yes just google it (instruction manual for Makita Chop Saw 2414NB ) Just like this. In google search and you could search for it on Ebay also
Mar 07, 2011 | Makita Garden
Had difficulty starting chainsaw DCS4610 for the first time. Think it was flooded. Problem now it wont idle.
Is this a new saw? If yes return it or at least ask for a recommended repair facility. Your saw is actually a Dolmar (owned by Makita) and a fine saw. In order to meet EPA requirements they are set very lean (many 5100s seize with factory settings). To protect your investment and not invalidate your warranty I recommend it be adjusted by the
professional recommended by the merchant where you purchased it or one recommended by Makita.
The starting procedure is probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Most new owners miss opening the choke after it tries to start or do not hear the pop when it does and flood the saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Does anyone have the manual for the Makita electric chainsaw model # 5014?
The Makita outlet has 2 different models neither the 5014. Open the saw, Download manual is an option once open.
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
This link has 3 electrics agian none your model.
Dolmar is the actual manufacturer of Makita saws. http://charlotte.preferredpower.com/DOLMAR/Browse.htm
Getting closer 5012 http://www.cpomakita.com/static/manual/www.cpomakita.com-5012b.pdf
HTH
Lou
Jan 23, 2010 | Makita 5012B 12'' Electric Chain Saw
ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing2.gif while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
Sep 11, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
I need an instruction manual for makita chain saw DCS34
you can purchase one from store.payloadz.com most manuals cost $ 8.99. hope this helps
Apr 23, 2009 | Garden
Garden Logo
251 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
