Question about Hotpoint Ultima WF860 Front Load Washer
My washer is full of water and wet washing! F-05 is on the screen.
Locate the filter open it and cleen inside that should do the trick the filter should be on the front of the washer or at the rear you dont have to be a genius to do it if its not visable there is a cover on the bottom of the washer on the front just pop it of or you should be able to lift it off twist it anti clockwise it might need a pair of pliers on it because of debris inside it remember anticlockwise ive got a hotpoint ultima same problem fixed now hope it helps
Posted on Sep 14, 2010
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
Water wont exit the machine.on the display screen it comes up saying -f.05
F05 means water level switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint Ultima WF860 Front Load Washer
I HAVE F -05 DOES NOT RELEASE WATER CAN YOU HELP
FO5 means pressure switch (9 water level switch) jammed on full.
Check pump filter and pump for possible blockage.
Pump and filter to be found at rear bottom right of washer, remove panel to gain access.
Please rate my solution.
Thanks.
Aug 09, 2009 | Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
On my washer screen it says F-05
Error code F05 is indicating that the pressure switch is jammed on full, this could be caused by the switch itself being faulty, the water not draining out properly, or the pump not working.
Check pump and clean filter
If still does not work, then I suggest you call an engineer.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My washer is saying F-05
Error code F05 is indicating that the pressure switch is jammed on full.
Make sure pump is working o/k and that washer is draining properly. Check filter.
If after doing all these checks and error reappears, then I would suggest you call an engineer.
Thanks
F-05 WD640
f-05 pressure sw stuck on full this is a faulty switch
Jun 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
