Question about Ovens
I used a GE electric range while I was house sitting(don't have the serial# or age of the stove, although it is a few years old). The home owner cleaned the oven using the self-cleaning feature prior to her leaving. I used the oven to keep pizza (in the box) warm briefly @150 degrees after it was delivered, and also to re-heat pizza at a higher temp on a pan after being in the fridge. That is extent of my usage of the oven. Upon her return, The homeowner found the colour on the oven walls had changed to pale including white streaks, also she found a small amount of fine powder of sorts on the floor of the oven. I have been asked if I used a caustic oven cleaner to clean the oven causing the problems. The answer to that is no. This oven is cleaned often using the self-clean method. Could a great number of self-cleans eventually lead to this happening, some type of breakdown? Have other customers complained about this problem? What else could have caused this? As you may presume it has created some unfortunate accusations and hard feelings all around. Thank you in advance.
  • Ovens Master
  • 11,800 Answers
It's from the cardboard of the pizza box - the heat has dried it and it has started to disintegrate, releasing all kind of chemicals and that fine powder (cellulose fibers). This is why heating recycled cardboard is strongly discouraged.
No, the self cleaning would generate a dark ashy deposit and dull the walls, not what you describe. Most likely the chemicals from the cardboard and the pizza have reacted in some unusual way with the leftovers from the self-clean.
Just bad luck so deny, deny, deny.
Posted on Sep 14, 2010
Thinking about buying a new GE range that has a 3000 watt specification ... our home is sixty years old and wondering if the wiring (240 v) can support the wattage. I don't know the wattage of our old...
Calculating necessary breaker size using ohms laws, says 3000 watts at 240 volts would use 12.5 amps and most range circuit breakers are 30 amp so it should be find
Aug 01, 2011 | GE Ovens
Hi I am trying to find out the age of a FP stove - FPRA610AW - can you tell? Serial 87252EUD141075
You can date most of your Fisher & Paykel home appliances very easily using the service at the following link:
Appliance411 Service How old is my appliance Age finder date of...
Jan 29, 2011 | Fisher Ovens
We have a Kitchen Aid Electric stove about 10 years old and there was no owners manual left from the last owner. This week we turned on the oven and there is no heat from the elements on both the bake and...
The first thing I would check is the breaker for the oven at the breaker box. I have encountered similar problems and a partially thrown breaker ( or one pole of a double-pole breaker) can cause this. Find your "range breaker" in your breaker box and cut it off then flip it back on. There is a good chance that might fix your breaker. If it is an older house with fuses, then the range would be on two fuses and one of them is blown. This happens to dryers also (if the right fuse/breaker goes, the motor runs but it won't heat)
Hope this helps
Jan 28, 2011 | KitchenAid Ovens
We have just bought a new house and the stove is about 20-25 years old A moffat the timer will not disengage to enable for us to use the stove. We have turned all the knobs and popped them out even left...
Lets try to reset the controls by turning all pwer to the range off.
Have you tried unplugging the range and then plugging it back in? If it is electric remember it is 220 volt so please use caution.
If this does not work, check your breaker box. The range should be on a breaker by itself. When you locate it, Flip it off for a few minutes and then flip it back on. Again always use caution when doing anything with electrical service. Be sure that you are standing in a dry place, etc.
If a reset of the power does not turn the timer off, please get back to me with the exact details of name/model number and type of range (gas or electric)
I don't know where you live so I don't know the regulations in your area.Was the home inspected before you purchased it? The inspector should have inspected the appliances to make sure they were working properly. If this appliance cannot be easily fixed. I would call the realtor who sold you the house and complain.
Dec 20, 2010 | Ovens
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
3 prong outlet/4 prong plug
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Sep 06, 2008 | Ovens
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
