Question about Olevia LT32HVE 32 in. LCD Television
Olevia 232-s13 32"
Exactly how do i mount this thing on my wall? have no manual, purchased a wall mount unit, but don't know where to screw the thing in
  • Anonymous May 20, 2009
    Looks like only 2 small screws towards top of tv....doesnt show anywhere where I can mount. =(
    Problem Solver:
  • 6 Answers
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
Posted on May 28, 2009
  • djoker04 May 28, 2009
    SAME
  • Curt Egbert May 23, 2012
    I went to Ace hardware and found 4mm fine thread screws. I bought 6 screws at 2 inches in length. Worked perfectly.
  • 979 Answers
Best bet is to go the wall-mount MFGR website and check out their instructions...accordianman
Posted on Jul 01, 2008
I HAVE OLEVIA 232-S13 . I WOULD LIKE TO CONNECT EXTERNAL SPEKRS . WHAT CONNECTORS CAN I USE ,AND GET THE VOLUNE VOLUME
Posted on Dec 11, 2008
How do I replace an old obsolete wall air conditioner
Not really my thing but I'll have a go anyway. As far as I recall these units are wall mounted and are not connected to anything other than a power outlet. If I'm right then it should be fairly simple to remove it from its mountings. Disconnect the power lead and then (probably) remove the cover so that you can get at the mounting screws. If the mounting looks like the 'hook on' type just slacken the screws and lift the unit up and off the wall CARE it'll be heavy. If it's not the 'hook on' type you need to support it BEFORE removing the screws otherwise it'll drop like a ton of bricks. Once it's off the wall you should be able to find the ID plate which should have the BTU output and wattage which you need in finding a replacement. Just had a thought, it's possible that the ID plate is on the outside of the AC unit, in which case you've got the info before you remove the unit.
I have no idea where you would go to get a replacement, there's not much call for them in the UK. Good luck.
Jun 29, 2015 | Heating & Cooling
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
The screw in the right filter area that is (approx. 12-13 inches has come loose. I have tried to put in back in place......no luck.Would it be advisable to take oven off the wall? OR, does anyone know...
Those screws screw into the support plate mounted onto the wall behind the unit. would guess it is not lining up for some reason or the hole is stripped out. Would have to remove the unit from the wall to inspect the mounting plate and make sure the hole are not stripped out. Lookt at the end of the bolt. do the threads look clean and not pulled or stripped???
Sep 29, 2017 | Sharp R-1870 Convection/Microwave Oven
Cs-ye12mke. Panasonic Inverter A/C system How do i access the drainage tubes behind or within the wall unit. The unit appears to be sealed with little access to the internal parts. It leaks down the...
There is step by step instructions in the online manual. I found the 3/4 ton (1 size smaller than yours) manual very easily. I suggest you read this. But there is 2 screws located behind caps under the discharge air swing fin. I suggest 2 people if you plan on working on the tube behind the unit, you don't want to damage the copper tubing, located in the exact same location.
Jun 23, 2017 | Panasonic Heating & Cooling
We lost the screw to mount the olevia 227-s11 65in.lcd tv on the wall and none of the screws would match that of the mounting bracket.where can we get the screws ?
you can get the screws in any hardware shop. just measure the dimension of the screw and mention it to the hardwareshop assistant.
Jul 01, 2011 | Olevia 227-S11 27 in. LCD TV
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I have 32 in Vizio and am using a full motion wall mount. It is attached to the smaller inner mount. I would like to attach it to the larger outer mount but dont know the screw size. It is larger than...
To know the exact size of the screw, you have to get the circumference of the hole where you will insert the screw. If possible to bring with you the outer mounting in buying the screw to have a perfect fitting.
Nov 30, 2010 | Vizio L32 32 in. LCD HDTV
Olevia 232 S12 wall mountable?
did you ever get it mounted? if so, would you mind telling me what kind of mount you ended up using? thanks!
Mar 09, 2010 | Televison & Video
In need of a owners manual for a model 542b11 42 in Olevia brand TV
I have the users manual. Leave me your email address and i`ll send it to you, it is about 6 megs in pdf format.
Dec 02, 2009 | Olevia LT42HVi 42 in. LCD Television
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
Olevia LT32HVE 32 in. LCD Television Logo
2,949 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
