Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
My samsung 40" flat panel is flickering. Image flickering.
5 Suggested Answers
The Machine
  • 788 Answers
SOURCE: blury display on flat panel TV when hooked to laptop
Try setting the resolution on your computer yo 1024X768 if you are using a vga cable, 800X600 for an s-video cable, or 640X480 for an rca (composite) cable.
Posted on Aug 13, 2008
toolkits
  • 1099 Answers
SOURCE: tv is flickering non stop and a has a low popping sound
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on May 23, 2010
  • 610 Answers
SOURCE: MY SAMSUNG 40" FLAT PANEL
This is usually caused by several capacitors failing on the power supply board. Samsung is covering the cost of repair on certain models, you can call 1-800-samsung to find out if you are covered and where the nearest service center is.
Posted on Aug 18, 2010
  • 8457 Answers
SOURCE: HI, I have a 40" Samsung Flat Screen TV (Model:
This tv 100% have problems with the main logic Tuner signal board that the board where the tv board that the tv incomming broadcasting signal wire plug into it.This tv might also have problems with the T-Con board too.The tv T-Con board that the tv board sit in the middle at the bottom of the tv LCD screen panel to project tv pictures pixels dots to the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com buy a whole refurbish main logic Tuner signal board and or a refurbish T-Con board for the replacement too.
Posted on Oct 10, 2011
Samsung LN46D630 screen flickers
The Tcon board or the LCD pnle is faulty ,can confirm by replacing the Tcon board. If you wish to get some more information about Tcon board problems and solutions then check the following link.
http://electro-medical.blogspot.com/
Oct 03, 2016 | Samsung LN46D630 LCD TV
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Tv flickers non stop on all inputs
Flickering can occur by many reasons. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 21, 2014 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung plasma power indicator light flickering
This is problem with power supply board .You need to replace electrolytic capacitors in power supply.(see image).Good luckeae0d3e1-1260-4d93-bdae-f47e56f73f19.jpg
Mar 03, 2014 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Hi I have a 40" Samsung is this a backlight fault or something else
Might be a back light fault, or the main board fault. Contact any service technician to confirm. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 11, 2014 | Televison & Video
Samsung LE40R71B flickering problem
appears other people are having the same issue with Samsung TV's.
Try calling Samsung or wherever you bought it from.
I've been dealing with Samsung on this issue.
We got a 40" LCD in October 2010 and it started flickering January 2012.
Changing it from 'standard' to 'movie' helped (natural and dynamic flicker)
Then it started flickering in 'movie.'
I called Samsung and told them this issue is all over the internet. They agreed to pay for repair, parts and labor, even though it's out of warranty.
The guy just left and this is what I know. He said that in the 46" and larger, the issue is a jumper. In the 40" and, I think, smaller, it's the panel. He's ordering the panel and will be back to replace it when it comes in from the warehouse in CA.
Try calling Samsung and good luck!
Dec 28, 2013 | Samsung LE40R71B 40 in. HD-Ready LCD...
Samsung 40 lcd tv fault
Does the line stay or does it come and go? You could have a faulty t-con/LCD panel connection. It could also be the panel itself !!!
Oct 30, 2013 | Televison & Video
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
