Question about Brother MFC 240C All-In-One InkJet Printer
Unable to print or copy, see troubleshooting 51
  • Brother Master
  • 5,340 Answers
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Posted on Sep 14, 2010
I had the "Clean Unable 51" error code and saw a bunch of different solutions. First, I tried the purge solution to no avail. Then, I read that something is probably caught somewhere or that pulling paper out from a paper jam could've misaligned a gear. So, I pulled out the paper tray, opened the cover, and the back piece to investigate. Nothing.
But, I noticed that every time I opened the cover or the ink cover, it would reset and try and print the document again. I did this about 4 times, and still it said clean unable 51. But on the fifth time, it printed! It seems that every time it attempted to print, it got a little further. I suspect dust buildup or something to that effect. good luck
Posted on Sep 06, 2011
4 Suggested Answers
  • 693 Answers
SOURCE: mfc240 c gives unable to print see troubleshooting
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Posted on Aug 14, 2011
SOURCE: print unable 51
Reinstalled driver from brother. unplugged from computer. unplugged from wall.  held printer upside down while plugged back into wall. (lots of encouraging noises) replugged printer (USB cable) back into computer. Whole F'ing thing works Go figure Buy Lexmark
Posted on Feb 08, 2009
SINN3D
  • 85 Answers
SOURCE: unable to print 51. what does this mean?
Here mate this should help: http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=eu&c=gb&lang=en&prod=mfc440cn_all&Cat=11
Posted on Jun 13, 2010
My HP 6700 says "unable to scan copy or fax.Can you help ?
There can be several reasons, so to help you troubleshoot the issue about unable to scan copy or fax, it is recommended to download and install 'Hp Print and Scan Doctor' from the link below:
http://support.hp.com/us-en/document/c03286146
Also, you can find more troubleshooting steps mentioned on the link.
GuruAid.com
Apr 08, 2016 | HP Office Equipment & Supplies
Printer wont print. error message says" print unable 51 see troubleshooting & routine maintenance chapter in users guide" I have no users guide!!
Maybe is you should provide the brand and model or you unspecified printer, could findyou the manual, if available.
You can llok for it too, search google with terma
manual, brand ans model
May 17, 2015 | Office Equipment & Supplies
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Unable to print or scan - copy only
that is a networking problem the fact the you can copy eliminates the possibility that there is something wrong with the printer / copier
Mar 25, 2009 | HP Office Equipment & Supplies
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
MFC-240C stopped copying. LCD showed: check Users Guide & Manuel Troubleshooting & routine mainteance. Print unable 51
This could be to several reasons:
a camshaft could be broken
purge station in disorder
ph not in correct position
Here are some clues:
pull papertray out and turn the paperfeeder by hand several times.
Open printer:
http://www.fixya.com/support/t475349-brother_print_unable_50_error
open printer and check encoder strip (foil runing parallel to ph traveling direction). Is it in right position going thru the ph carrier?
Turn one of the big lefthandside gearwheels several times by hand
Apr 04, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
539 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
