Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Need software driver for simpledrive 96300 - SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
4 Suggested Answers
SOURCE: USB external hard drive driver
If you go into Computer Management and go to Storage > Disk Management. You'll see the partition there. Right click on it and assign it a drive letter. You will be able to access it from there.
Posted on Jan 30, 2009
  • 10406 Answers
SOURCE: My hardrive "simpledrive" model 96300-41001-156
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
  • 171 Answers
SOURCE: I have a Model 96300-40001-001
Try to put in another usb port,if not change the usb cord.Good luck.
Posted on Feb 09, 2011
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Windows 7 hp does not recognize simple tech simpledrive 96300-40001-001
Yes you need new driver, but Driver Utility can't help you. I've used it before and I can tell this driverupdate us tool is x100 times better. Take a look and enjoy
Jan 25, 2012 | SimpleTech SimpleDrive Portable USB 2.0...
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
My PC does not recognize the external drive 96300-40001-001
Driver Problem:
Check whether any other PC or operating system does or not.
If recognized insert the installation disc and reinstall the drivers for ur drive on your PC.
If not recognized again try the aabove installation.
If this fails, contact service centre or drive manufacturer's tech support.
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
Power supply
The power supply for a SimpleDrive 96200-40001-001 is MHAU11306D300.
Mar 04, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Lost software
For which operating system you require if you want for win98 you can download from drivergide.com
Feb 24, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Computers & Internet Logo
1,374 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
