Question about Philips 50P8341 50" Rear Projection Television
Philips 50 inch tv
Picture was taking awhile to come on an then it went out and will not come back
have sound but no picture
  • Philips Master
  • 3,459 Answers
Check the site www.magnavoxhelp.com. They may have kits to fix this your problem.
Posted on Jun 24, 2008
The projector is probably bad
Posted on Jun 10, 2008
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
PHILIPS 50 Inch HD DLP Projection TV the picture went out suddenly and there is not sound but a loud humming-buzzing coming from the set...any ideas on what could be wrong or if it can be fixed?
It's the optical block (color wheel) and the same thing happenned to our Philips 50" DLP. From what I've read, it's not worth the trouble & $$ to fix. Dig a hole!
Oct 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I was watching Dish Network and my Philips 50 inch Plasma showed a line in the middle of the screen and then it made a snap sound and the picture went out at that time. I already replaced the power supply...
The capacitors in the power supply you replaced it with are probably blown. Take off the back of the TV and check the capacitors... shown in the picture (in a similar philips model). If they are bulging out instead of flat on the top... they may be bad. If you replaced the power supply before with a unit that had the original capacitors in it, they wear out and only have "X" amount of hours of life. (More below pic)
As far as sound... you may replace the sound board. It's shown in the photo in the center bottom right. Not sure on your TV without opening it or checking the model out more. Good luck
Oct 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Philips 50P8341 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
