Question about Kenmore Elite 45986 Front Load Washer
Lid lock does not work - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
  • 2 more comments
  • HHK1945 Sep 18, 2010
    Thank-you for making this information available. I would like some pictures. I purchased my washer 2nd hand, and I do not have a manual. I appreciate this information.
  • blueextc3221
    blueextc3221 Sep 18, 2010
    http://media.fotki.com/1_p,wkkrqtwwwgtsg...
  • blueextc3221
  • HHK1945 Sep 20, 2010
    This is FABULOUS! Thank-you very much. This will be saved under 'FAVORITES."
Why the lid locking led is blinking after lock the lid and stay standby with out working ?
The unit will not operate in this condition until the lid lock signals a locked condition. The controller is signaling that it believes the lid is not locked. Assuming the lid is actually locked, then this might occur because of a bad wiring connection (check the lid lock switch assembly and the cabling at the controller) or a bad lid lock switch/sensor.
Dec 05, 2014 | Maytag Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
The machine went through a cycle and stopped in the middle of a rinse cycle. Trying to restart, the red lock symbol kept lighting up and would hear the lid lock mechanism activate. Tried switching machine...
if the lid lock is activating then testing it electrically wont help. you say that the lid lock is working when you manually put the lid lock in the closed position., is that correct?if it is, does the machine work on the spin cycle once you have manually activated the lid lock? have you checked for damage to lid? please reply 4 more help.
May 23, 2010 | Fisher and Paykel Washing Machines
Control panel flashes a "FL" sign
Hello washerproble,
You mention the Service Manual good, that has more info then the troubleshooting guide packed in the console of the machine. The TS guide has the schematic which is very handy. Do you feel OK to troubleshoot and try a DIY repair?
I’m an owner and have not experienced your problem but I can simulate the “FL” error on my working FAV6800AWW. Looking at the schematic of this machine the control board wants to see input from either the left or right side lid lock to signal the control board that the “Lid Is Locked”. Can you select Spin only cycle and press the start button … do both lid locks close and lock the lid? If they did and you still take “FL” error you have loss of signaling “Lid Is Locked” form the lid locks back to the input of the control board. Pull the washer power cord from your 120VAC service outlet and try reseating the lid lock plugs into the connector of the left and right lid lock. Maybe a loose plug or corrosion, only one of them needs to work to signal the control board the “Lid Is Locked”. The left lid lock is the important one because of its dual signaling function back to the control board. It has the reed switch in it providing the signaling the “Lid Is Closed “ to the control board which is operated by the lid magnet. If you still take the ”FL” error you would have to start trouble shooting toward the control board to find the loss of “Lid Is Locked” signaling to the control board. The easiest thing to do if you feel the machine is a keeper is to invest in the left lid lock and replace it and see if that gets you back in service. Again only one lid lock is necessary to signal the control board the “Lid Is Locked”. This site has a link to parts just type model number
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169371 The Left Hand Lid Lock is this p/n AP4033944
Feb 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
101 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
