Question about Watches
Watch not working replaced batt. worked for an hour then stopped
Often batteries loosen over time check to make sure it is firmly in place a small piece of paper will usually help hod it in place
Posted on Sep 14, 2010
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
New Invicta Men's Diving Watch--stops working after I set it the first time. I set it again,it works for awhile then stops again.Help
The problem you are describing is in the electronic timing module and there is nothing you can do but return it to the place of purchase for exchange.
Jan 13, 2011 | Invicta Watches
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
It stop working, analog and digital
Unfortunately the watch may have been on display for some time and the battery may have run low. If you go back to the place of purchase they should change the battery free of charge. Make sure that you have the watch resealed to manufacturers water resistance rating or you void Sectors warranty. The retailer may also replace the watch with a model in stock but you may have the same issue with display time effecting the battery life.
Sep 17, 2009 | Sector 3251908015 Mountain Master watch
Ebel Wave lady's watch battery
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
The watch stopped working
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Apr 08, 2007 | Prague 49011-M1
Watches Logo
76 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
