Question about Black & Decker Irons
My black and decker icr5000 first impressions iron won't change to red so it can heat up
  • 4 Answers
SOURCE: Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Posted on Feb 18, 2008
SOURCE: Cleaning a self cleaning iron
My iron went into cleaning mode and I don't know how to stop it from doing this. I don't need to clean it now. How do I get it to stop?
Posted on May 24, 2007
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Posted on Sep 30, 2007
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
How i can repair my black and decker iron
heating element should be change,by expert professional
Oct 13, 2014 | Irons
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Aug 19, 2009 | Black & Decker D2030 Iron
Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Jul 26, 2009 | Black & Decker Irons
The black and decker iron wont heat up
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Black and Decker AS775 Iron won't reset to heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 22, 2008 | Black & Decker AS775 Iron
Irons Logo
111 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
