Question about HP Office Equipment & Supplies
How do I install an ink cartridge? HP photosmart c5280 All in one
    Genius:
  • 1,447 Answers
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door how do I install an - c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts how do I install an - c00956271.gifttp://i.fixya.net/uploads/images/c00956271.gif" alt="c00956271.gif" class="h_mi" />
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge
  7. Close the print cartridge door. Figure 6: Closing the phow do I install an - c00956273.gife door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
Posted on May 15, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 15, 2008
    Installing the print cartridges
    NOTE:
    The HP All-in-One must be turned on before you can insert the print
    cartridges. When the HP All-in-One is turned on, the print carriage is on the right
    side. The CD/DVD tray must also be in the up position before installing the print cartridges.
    1. Lift the print cartridge door.
      Figure 1: Lifting the print cartridge door
      Figure 2: Opening the print cartridge door
    2. Remove the tape from the print cartridges.
      Figure 3: Removing the tape
      CAUTION:
      re-tape the cartridges.
      Figure 4: Do not touch ink nozzles or copper-colored contacts
    3. Insert each print cartridge as follows:
      1. Hold the cartridges with the HP logo on top.
      2. Insert the tri-color cartridge in the left cartridge slot and the black or photo cartridge in the right cartridge slot.
        Figure 5: Inserting the tri-color cartridge
      3. Make sure you push the cartridges in firmly until
        they snap into place.
        Figure 6: Pushing the cartridges in firmly until
        Figure 7: Properly installed cartridges
      4. Close the print cartridge door.
      5. Press
        OK
        when prompted to confirm the installation
        of genuine HP print cartridges.
    You can find info on this link INSTALLATION
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Posted on Aug 04, 2008
SOURCE: HP Photosmart C5280 printer - 1 month old not printing correctly
hp c5280 replaced the ink cartridge and the heads will not align, took out an put back in an they still will not align.
Posted on Sep 17, 2008
ginko
  • 19396 Answers
SOURCE: HP photosmart C5280 Manual
Manual here: Manuals
Here is the support page with more documentation:
HP Photosmart C5280 All-in-One Printer
Posted on Jan 05, 2009
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
SOURCE: Ref HP Photosmart C5280 All
Refer to printer documentation
Posted on Jan 19, 2011
Red exclaimation mark on C5280
Try first unplugging power cable, and see if it clears the error
Jul 29, 2008 | HP Photosmart C5280 Printer
I have installed 2 new ink cartridges. The orange
Are the cartridges genuine new hp, or are they compatibles, or refills? If not genuine hp, get some and see if that solves your problem.
Apr 25, 2010 | HP Photosmart C5280 Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
HP 5280 Photosmart won't print??
I replaced my ink cartridge on my HP 5280 Photosmart. Now it says, "refer to printer documentation". What do I do?
Jun 23, 2009 | HP Photosmart C5280 InkJet Printer
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Jan 18, 2009 | HP Photosmart C5280 Printer
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
plz try by reinstalling the drivers if the problem is not solved then your printer needs servicing
Jul 01, 2008 | HP Photosmart C5280 Printer
Printer
The manual can be downloaded here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=au&dlc=en&product=3204464&lang=en
Then follow the instructions.
Good luck.
Apr 18, 2008 | HP Photosmart C5280 Printer
602 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
