Question about Watches
Dalvey st elmo clock how to change batteries and start working
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    How do I change the batteries in a Dalvey St Elmo clock
    I woud try this link then their link to customer support or the contact us at the bottom of the window http://www.dalvey.com/shop-online/clocks-barometers?gclid=CKKZ0vTuqMMCFQqSaQodvkEAdg
    Jan 04, 2015 | Watches
    I have a Sharper Image Swivel Worldtime Clock model # M1600/M1601 I have lost the instruction manual. I need helpin changing the temp. fromCentigrade to Farenheit and I need to change callender mo.and...
    To change the calendar, push the mode button until the calendar section starts flashing. Then press the up or down button to move the calendar month and year first. Once you get to the right month and year, press set, then the date should start flashing. Again, use the up or down button to get to the correct date, then push set. That should get it done.
    Regarding the temperature, I used to know how to do that but am now basically clueless. My batteries went out, and when I changed them the temp started up as Celsius and I cannot get it fixed.
    Nov 23, 2010 | Watches
    Need a replacement crown for a st dupont watch model 155 F1 Bl07
    GOTO
    http://www.watch-clock-makers.org/
    Hope this tip helps.
    r/ David
    http://antiqueclock.clockstop.com/
    Mar 11, 2010 | S.T. Dupont Watches
    How can I start a small Quartz clock?
    The first thing to try would be to test the battery. If the battery is good the problem may be the mechanical works need to be started in motion. If it has swinging parts try to get them swinging. If it has hands set the time on the clock. Hold the the clock in your hand with the face towards you and rotate it clockwise a few times to get the gears moving. Sometimes just letting it sit upright for a day or so will be enough to let the clock start working. I hope this is helpful to you.
    Carol.
    Apr 12, 2009 | Watches
    Changing the time on my wristwatch
    For the Amritron 45/6975:
    From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
    Mar 08, 2009 | Armitron Two Tone Sports Watch
    Change watch setting from 24 to 12 hr clock
    armitron watch 40/6601 instructions
    Jan 19, 2009 | Watches
    Timex 1440 sports watch, WR50M
    In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
    Feb 15, 2008 | Timex 1440 Nylon watch
    Watches Logo
    660 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
