Question about Swintec 7040 Typewriter
I have a new lift off correction spool for a 2640 Swintec, but it doesn't correct? It seems to be working correctly, but doesn't lift off the type.
  • Swintec Master
  • 3,594 Answers
You may have it on backwards the dull side faces the paper.
DickyO
Posted on Sep 14, 2010
How to replace correction tape?
From the looks the typewriter is not electric but electrononic. Wind it the same way the old lift off tape was guided. The full spool on the left hand side around the guides in the front of the printwheel to the right side with the empty spool. Simple.
Feb 12, 2016 | Swintec 2600 Electric Typewriter
Swintec 2640 Typing wrong characters
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
DickyO
Mar 17, 2014 | Swintec 2640 Electronic Display Typewriter
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
Memory on Swintec 7040 is irratic. Copy is correct but tabs move around.
Spray a little WD40 on the silver shaft that the carrier slides on.
DickyO
Sep 17, 2012 | Swintec 7040 Typewriter
As soon as I turn our Swintec 2640 on it starts beeping very rapidly.
Be sure the printwheel doesn't have any bent or broken spakes. Try it without the bribbon and correction tape to see if they are hitting the P/W.
DicyO
Feb 15, 2011 | Swintec 7040 Typewriter
How do I use my repeat key on my Swintec model 2640 typewriter
The repeat key just types the last letter you typed over and over
DickyO
Jan 14, 2009 | Swintec 7040 Typewriter
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Swintec 7040 Typewriter Logo
61 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
