Question about Astar LTV-19BG TV
Clor stripes on screen. Can not turn off tv unless i unplug it
    President:
  • 635 Answers
The color stripes can usually be fixed by opening your monitor and re-seating your lcd screen. The alignment tabs often slip on these generic models, pinching off the liquid lcd before it can reach the screen. Your other problem is caused by an inferior infrared receiver led. These can be replaced with a generic infrared receiver from radio shack. There are only 2 to 4 pins that need to be de-soldered to fix this. Many ppl think that the remote has drifted off frequency and needs to be dialed back in, and this simply isn't the case. Replace that led and your remote will work perfectly again.
Posted on Sep 14, 2010
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Why does my lcd tv get stripes on it?
You are about to buy a new TV soon.
Lines have nothing to do with whether you watch XBOX or TV.
Oct 01, 2012 | Televison & Video
The tv screen has gone pink. no other clor, just pink.
Tv have 3 colors guns like R,G,B colors.Tv is missing one of it color gun.Have a soldering iron and a roll of solders? Take the tv aparts,resolders the video board soket pins holes that connected to the CRT-(tv tube).Resolder the Yoke wires like R,G,B connected to the main board too.Will solved this problems.
Mar 16, 2011 | Curtis-Mathis CM32010 TV
My TV Screen just turned off, but I hear the sound, have no menu.
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a mitsubishi model number vs60803, when i turn it on the picture is fine, but after a few mintues of watching tv. the screen spits into 2 clors, blue and red almost like 3-D
It's possible you have cold solder joints on the Convergence IC's. There are two of them in your set. They will be mounted on large finned heat sinks. It will require soldering.
Jul 14, 2009 | Mitsubishi Televison & Video
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Astar LTV-19BG TV Logo
202 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
