SOURCE: Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
SOURCE: Polycom Sound station - help it won't work!
This modelo has a separeted wire to the wall telephone jack ? If it is the case, once I had a problem like your and was the plug in the end the wire, I just cut out 3 ou 4 inches in the wire and clip another new plug and it was fine. These plug its a regular analog telephone pluf easily found in a eletronil part shop. I hope I had help in anyway.
SOURCE: HDX8000 with ISDN
Please confirm if you have made video call or audio call. There is an option in the called basic mode, if it is enabled then disable and check. ckeck with service provider for the bonding option. Last option you can try SW upgrade
SOURCE: How do I find the MAC Address for my Polycom ViewStation ISDN Video Conference?
I just called Polycom and the guy said it starts with 0003 or 0004. Sure enough I had one of those numbers, it was the same as the serial number on the box the phone came in. This number is found on a sticker on the back side of the phone. Easy to find, but not labeled as a "mac address"
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
you may need to install either skype ,yahoo messenger or a similiar type of message program
if you choose skype
when you install skype you will have the options to join make/id or if already a member to sign in
an Id must consist of letters and numbers just one number will do the Id must be unique skype will automatically search to see if your Id you have made is available eg: loosey9
then
open skype go to tools from the drop down list select options scroll to audio settings also video settings you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
in the audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make the right changes?
you should be ready to go
i would suggest you make a log of your skype id and password either on a note pad or a removable usb drive incase of any memory lapses
don't forget to vote
