Question about GE Washing Machines
Gear oil in wash tub - GE Washing Machines
    President:
  • 1,314 Answers
Change transmission
Posted on May 16, 2008
Why is there oil by the snubber ring
Agitator/Spinner/Outer Tub/Transmission. Are you sure its oil, lots of parts , gear oil transmission, it needs repairs asap before it will burn out. Call repair man . Or check warranty.
Jul 08, 2015 | Maytag Washing Machines
Oil inside tub after spin cycle coming from gear shaft
IHAVE THE SAME PROBLEM IN MY FRIGIDAire washer dryer stach top loaded machine, the oil and smell of oil comes after finishing spin , do you have a solution because I called the company dealer in my country and they want 400 dollars to fix it, I think they are steling coz the machine is working and spinning but only little oil with smell come at the end of the washing.
any help
thanks
May 07, 2011 | Frigidaire FWS833A Top Load Washer
My Sears model 110 will wash but won't spin. Sounds like it is locked up and the motor just hums.
-If the motor was not running at all i would say you have a bad lid switch.
- If the motor is definitely running then look under the washer at the interior cabinet about level with the bottom of the tub for signs of oil. If you see a ring around the case- you have a bad transmission.
-If no oil MAKE SURE it is still washing and doesn't just sound like it is as you may have a bad drive coupler.
-If the machine is washing, has no oil and just will not spin you may have one of the following:
-wash tub fallen and contacting outer tub due to worn drive block (check for space under agitator)
-item lodged between tubs- use flash light to look at all of the holes on bottom of tub as well as at top between white tub cover and inner wash tub balance ring
-something jammed in pump- unusual to still have wash action as pump is still running in reverse (sucking water back) but may have something that gets driven into it when trying to drain/ spin
-defective gear in transmission not allowing neutral brake to shift out to spin
Jun 11, 2010 | Washing Machines
Oil is spewing into the wash tub during the spin
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
Mar 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Sep 27, 2009 | Whirlpool LSN1000LW Top Load Washer
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Washer leaks under tub
Can you see exactly where the water is coming from? When the machine is spinning and you lift the lid does it stop in less than four seconds? Does the water come from the side of the tub near an area where a tube attaches? Is there water staining down the side of the tub and an area near the top shows leaking? Is there rust and oil stains at the base of the gear case? Please blog back, SearsTechToo.
Oct 06, 2008 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
