Question about Toro Lawn Mower With Toro Power Tools
How to put a new drive cable on - Toro Lawn Mower With Toro Power Tools
    Problem Solver:
  • 9 Answers
What kind of mower?
Posted on Sep 15, 2010
Broken mini usb contection
If your talking about the cable, replace the cable. If your talking about on the external hard drive, either replace the drive if it's under warranty or go buy a new external hard drive enclosure, open the samsung HDD, put the drive in the new enclosure. Opening the enclosure will typically void the warranty.
Dec 23, 2012 | Samsung G2 Portable External HX-MU050DC/...
How do I get the second hard drive out of a dell precision 670
Hello there. before going into the Case make sure to touch the metal
Power down the PC and remove all cables
Open the side of the Case find the hard drive you want to remove unplug the two cables connecting to the hard drive and slowly remove the hard drive from the bay you may need to UN-screw the hard drive.
put in the new drive into its bay connect both cables put the case back together connect all the cables back to the PC boot the System up and reformat the new drive .
If you need anymore help with this problem let me know, i have done it many times myself thank you and don't forget to Rate
Jan 26, 2011 | Dell Precision Workstation 670 PC Desktop
How do u replace a speedo cable on a 1989 FLST/C
As best as I can remember, the speedo cable comes off the front wheel on this model. You'll have to remove the trip reset knob and the center nut that holds the dash on. Remove the dash and unscrew the cable from the bottom of the speedo. Notice how the cable is routed to the wheel drive unit so you can put it back in the same location. There is usually some "flats" on the cable down at the drive unit that are about a 1/4". Use a wrench or a pair of pliers to unscrew the cable from the drive unit. Installing the new cable it the reverse of removing the old one.
Don't forget to lube the new cable. Take the inner cable out of the cable housing, put a wad of grease in your hand, and drag the inner cable through the wad of grease to lubricate it.
Good Luck
Steve
Oct 05, 2010 | 2000 Harley Davidson FLSTC Heritage...
New DVD
Say what drive model you are replacing. The  IDE interface ribbon cable is a broad PATA cable that plugs into the the slot at rear of the drive ,its the only place it can go .IF your cable is a narrow one you need a drive with a SATA cable.
Regards Bill
Mar 09, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
2000 chevrolet tahoe - can't put the gear stick in park. Can put gear stick in reverse and drive. Can drive and drive in reverse. But cant put gear stick in park.
The Shift Interlock Is Not Working Check If Brake Lights Work If Not May Be A Fuse Prob Or Brake Light Switch The Switch actuates The Lock
Mar 04, 2009 | 1995 Chevrolet Tahoe
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
My pc model: gateway gt5032 drives is not good
buy a new one. any monkey with a phillips screw driver can pop the lid on a desktop box, unplug the data and power cable to the drive, and then put in the new drive, re-attach the cables, and then put the lid back on.
Sep 26, 2008 | Gateway Computers & Internet
Which jumper is slave on my disc drive?
Greetings my friend...Put it to cable select mode(CS) so that the cable will automatically set your existing HDD as master and the new one as slave!
Oct 19, 2007 | Computers & Internet
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
