Question about HP Office Equipment & Supplies
When I try to print a colored card on HP gloss Print paper i'm told that I'm out paper & my hopper is full.
  • fcanepa229 Sep 14, 2010
    I have printer on gloss paper before Make of printer is HP Officejet J5780 All-in One
    President:
  • 2,777 Answers
It sounds like it can't detect the paper, have you printed on glossy paper like this before? Have you removed all regular paper and are just inserting the glossy paper? Let me know and I can help for sure. Also, what is the make and model of the printer you are using? Probably an HP, but then I need the model number as well, it should be right on the front of the printer.
Thanks
Tim
Posted on Sep 14, 2010
  • Tim Grayson
    Tim Grayson Sep 14, 2010
    I see, and yes that printer is definitely capable. I would try unplugging the printer from the wall for a good 2 minutes, then replugging it in and powering up. Take all paper out aside from the glossy paper, and make sure it is inserted in as far as it will go into the printer. It should definitely detect it and grab it, try to reprint...
    Does it still have the issue?
    Thanks
    Tim
Color print not coming proper on 300 gsm cards
Well, I think that is over spec for your machine. Are you using a coated stock? What type, gloss, silk, matte? Is your paper cut 18 x 12?
Mar 22, 2014 | Konica Minolta Bizhub C220 Color Copier
After installing a new graphics card in my computer I get " To use advanced dot placement mode select a border paper size and load the paper tray with genuine Kodak Gloss photo paper and run the print...
That doesn't seem like video card issue it sounds like a printer driver issue. Check your print settings and make sure it's set to simply black and white or just color....and uncheck advanced dot placement mode.
May 28, 2011 | Computers & Internet
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
THE PRINTER WILL PRINT ON NORMAL PAPER BUT NOT ON kODAK PREMIUM P
Ok,, thanks again for the additional info. I had the same problem at one point with my HP photo printer, it seems the electronic eye that watches for the edge of the paper somehow can't see/focus on some of the high gloss papers.
How I tested it was simple. I roughed up(wrecking) one sheet and ran it through, it saw the page and printed. after that I tested with semi-gloss and it seems to work better.
Give that a try and let me know if that works.
Chris
May 27, 2009 | HP DeskJet 932c InkJet Printer
Canon I960 inkjet printer color shifts
We are experiencing something simillar with our imagepress. As far as I know, every heavily used Canon (or used for a longer period of time) tends to skew colors towards magenta a little bit. We are dealing with it by reducing magenta in color balance menu for all jobs on the printer, but the result is never perfect (especially in grey where is needed perfect balance of colors).
Mar 12, 2017 | Cannon Canon i960 Photo Printer
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Printing
I wonder if it is in fact a printer problem? have you tried different programs?
Aug 18, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
HP color LaserJet 2550n
Look at your printer properties and check that you are using the correct tray settings.
Jun 12, 2006 | HP Color LaserJet 2550n printer + HP Color...
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
