Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Setting low pass and bass eq
I am powering one 15inch Kicker L7 (2000 watt peak, 1000 watt rms) at 1ohm
what low pass HZ setting do i set it to and how do i set the bass eq without damaging either of the equipment.
    Genius:
  • 1,066 Answers
The only thing that might damage equiptment other than playing it too loud would be running at 1 ohm if not supported by the amplifier.
as far as the eq and crossover settings, that is dependent on personal preference, and the acoustics of the paticular vheicle installed
Posted on May 17, 2008
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
No problem just need advice
if you use for bass need to adjust to a 120Hz in the amp & eq
Apr 26, 2010 | Performance Teknique ICBM-772 Car Audio...
Watts
The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
Details:
  • 150 watts RMS x 1 at 4 ohms
  • 300 watts RMS x 1 at 2 ohms
  • MOSFET power supply and output stage
  • STAR Topology for cleaner sound
  • Bass Engine® features:
    • low-pass digital crossover, 30-200 Hz, 24 dB/octave
    • variable subsonic filter (15-50 Hz in 5 Hz steps)
    • parametric EQ variable from 30-160 Hz
    • Bass Compensator enhances low-end definition
  • top-mounted digital control center with cover
  • time correction 0-10 milliseconds in 0.5ms steps
  • phase correction 0-180° selectable
  • digital readout
  • detachable front cover
  • blue power LED
  • delayed turn-on
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • speaker- and preamp-level inputs
  • gold-plated terminals
  • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
  • 1-year warranty
May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
141 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
