Question about Kenmore Quick Clean 30012 Vacuum
The vacuum picks up dust, dog hair, etc. but then spits it back out when I turn it off. I have taken apart the cylinder in front to empty it and remove any clogs, but that hasn't fixed the problem. I am very frustrated.
  • vealefamily Sep 14, 2010
    there was a piece of plastic blocking the hose. I took that out, and now as I vacuum I hear it pick up dirt but then I see it get spit back out as I go across the kitchen floor. any other ideas?
  • vealefamily Sep 15, 2010
    You are a guru! Very helpful, problem solved. Thanks.
  • 2,299 Answers
The problem is in the hose. Take the hose off and take a broom handle and stick it down the hose. There is something caught in the hose I bet!
Posted on Sep 14, 2010
  • Rodney Clark
    Rodney Clark Sep 14, 2010
    You may need to take the bottom of the vacuum apart to see if there is something stuck up inside. There has to be a blockage somewhere. When you remove the hose does the hose have vacuum on it? If so then it is in the lower part of the vacuum. Sometimes they get plugged up below where the hose attaches in the lower part of the vacuum.
  • Rodney Clark
    Rodney Clark Sep 15, 2010
    Thank You! I am glad I could help!
My floor brush is not turning or picking up dog hair/dust, I took it apart and cleaned
Be sure to install a new belt, belts lose elasticity and need replaced once or twice per year.
Feb 08, 2017 | Vacuums
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Dyson dc59 troubleshooting
Have you checked the rotary brush at the front. Although IO dont have the same model of dyson I need to clean out the dog hairs that get wrapped around the main rotary brush which is easily got to by turning the catches with a coin under the cleaning head. They should have a little arrow or padlock symbol showing which way to turn them
Aug 17, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
My Bissell BS3920F upright (similar to the 10N6F) has been working wonderfully for the past 3 years but suddenly seems to not pick up dog hair as well as it used to. It has been pulled apart by my husband...
Check to see if your brush is not worn down, they do wear with age - compare the length of the bristles with a new one. Replace the brush ir there is a significant difference in bristle lengths. Also check the flexible bend where the pick-up head joins onto the upright section for blockages and fluff.
Feb 24, 2011 | Bissell Vacuums
Stuck front wheel
I have the same problem, but it looks like no one has the solution. I have taken the screws out of the wheel but that doesn't help remove the wheel to check what is stuck. Help us!
Jun 14, 2010 | iRobot 1100 Dirt Dog Bagless Robotic...
My wind tunnel had a lot of dog hair at the intake hole from my renter that used it. I was able to remove it, but is it possible there is hair up inside beyond the hole & how would I remove it? it is...
I have an upright Dyson Cyclonic.  Because I have dogs, I also have a Miele Pull-along.  I use the cyclonic for fine dust after picking up the hairs with the Miele.
Much quicker in the long run.
Otherwise I would waste a lot of time cleaning out the Dysan Cyclonic airways.  I usually use long nose pliers to get the ball out and then I use my Miele to **** the rest out of the Dysans airways!!!
Jan 16, 2010 | Hoover U5453-900 WindTunnel Supreme Bagged...
Washing the cyclone
Hi John.
Try this site for help http://dysonmanuals.llc.nu/
The Dc08 poor suction manual covers complete strip down of the cyclone unit,
Aug 31, 2008 | Dyson DC08 Cylinder Bagless Canister...
Dog hair from vacuum is being laid back onto carpet
my plush carpet and dog hair do not go together! I realized with this particular model and in my environment, the bag fills in one vacuuming! I literally dug out all the dirt I could by taking it apart and then changing the bag. Voila!
Mar 31, 2008 | Hoover WindTunnel Widepath U5397 Vacuum
Vacuums Logo
180 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
