check to see pump is primed and pumping, could have broken impeller or plugged with trash, use a makeup mirror and a flashlight to look in the hair basket water entrance to the pumps impeller fore damage or debris.. always prime the pump with a fw gallons of water after any repair or service.
Jay the pool pump repair guy longwood florida.
it will if you take the filter off and clean it or replace it ...make sure you get a new screen trash will come from the bottom of your tank back into your fuel lines ,,sea foam once used will leave these deposits in your tank ..might want to clean your tank then reinstall the pump
filling the filters before installing will make priming go more quickly. once the pump is primed crack open the fuse line at the injector while cranking until you have fuel pulsing out, close it then move on to the next injector. keep doing this until the engine runs smoothly. it may start running before all the injectors have been purged so keep clear of all moving parts and a fire extinguisher handy would be a good idea.
just might be trash in the pumps impeller. unscrew the center pump hose and with a flashlight look to see if it has a blockage. these are high volume pumps and require the spa to be full. jay the pool pump motor repair guy in sunny longwood fl
firt thing to check if the pump has water in it (primed) yes ? the impeller is plugged with trash and will need to be cleaned the pump will need to be taken apart and a piece of wire works well o get all of the trash out of it, a new hair basket will stop this from repeating
TRASH IN YOUR IMPELLER OR WORN PUMP, TAKE PUMP AND SPLIT IT LOOK TO SEE IF YOU HAVE TRASH IN YOUR IMPELLER AND LOOK AT OTHER PARTS FOR WEAR .. PRIME THE PUMP W/ WATER AFTER ANY PUMP REPAIR !! .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
must have water in it to prime ,fill up the tank with about 4 gallons of water or may have the impeller is broke or it could be plugged with
trash make sure you pump basket has no cracks , see picture on how 2
remove your pump .find your local pool pump motor repair guy and ask
him
how 2 take better care of your pump.. he can save you thousands of
dollhair$ over the years .. jay pump guy longwood Florida
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
