BX-40 bass amp works great for about 10 minutes then starts to cut in and out?..I let it cool down for a while then the same issue every time? any ideas? Thanks , Craig
  • 17,130 Answers
It is having a thermal runaway as the output transitors are heating up to cut off . so first of all release the loaded speakers to test if the fault changes. If so you r speakers must be checked for mismatch of impedance.
Otherwise the power amp circuit must be checked for excessive biasing check stage by stage, check for leaks in preamp stage that makes the output run wild.
Posted on Sep 14, 2010
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in...
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
May 24, 2011 | Fender Musical Instruments Corporation...
Works great for a period of time then- it starts a pulsating hum. Sometimes it happens after 30 minutes and other times it is a couple of hours before it starts.
it sounds like a bad sub woofer amplifer, as the unit heats up the capacitors start to leak and the amp will try to shut down. it would depend on how hard you are driving it, (heavy bass versus light bass) that would cause it to fail sooner than later. You need to replace the internal amp
Mar 20, 2011 | Velodyne DPS-10 Subwoofer
I have an Alpine M500 mono amp that works great, until you turn up the volume. I can adjust the bass down at the head unit, but at higher bass the amp shuts off. And then comes back on after a couple...
I don't think either, I believe your running theamp load too low with too low an ohm speakers and this cases the amp to produce more power but not stable and it overheats and the thermal protection cuts the amp off when the temp gets too hot to prevent damage.. Make sure your speakers depending on how they are wired do not exceed the amps load rating
Oct 26, 2009 | Alpine MRD-M500 Car Audio Amplifier
Amp keeps cutting on and off
Do you own a capaciter if not get one. If that dont help check all your wiring make sure it is the proper thickness and lengths.
Jul 30, 2009 | Alpine MRV-F540 Car Audio Amplifier
Cuts off in warm weather after about 10 miles
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
May 20, 2009 | 1996 Dodge Neon
Crate BX 160 bass amp. Has intermittent problems and shuts down
check your speakers cables for good condition-no touching between inner wires of each other- after you confirm from good cables condition- try the speakers one by one-make good ventilation around the amp and clean it with air blower-after that if the problem still found contact near service center for help.
Jan 20, 2009 | Audio Players & Recorders
I have a crate BX 160 that shuts down at the point where it starts limiting and then after a about 30 seconds. it starts back up. I would like to get a schematic on this particular piece of equipment...
I just saw your post. I happen to have a Crate BX-160 and was able to call Crate in St. Louis and talked with a tech there at the plant and he actually sent me full schematics for free.
Your problem, based on my electrical background and fixing audio equipment for 10 years, seems to be related to the built-in limiter in the power transformer. In other words, you might just need a new power transformer and it is a piece of cake to install (all push-on connections).
The schematic will show you the many test points for voltage checks, but unless you know what you are looking for, its just information overload. It is a rather simple amplifier and built resonably well. I have been using mine since 2003 and have fixed it a few times (age related problems like loose connections). There just is not much to go wrong on them except for the fact the amp is subjected to extream vibration. THis causes physical connections to fail resulting in vexing issues that are hard to solve. This is not unique to this amp (all bass amps).
I would bet anything your problem is the power supply shut-down circuitry is malfunctioning. In my expereience with amps, unless the amp is drawing current (failing power circuitry) and making strange sounds, the failure is usually not related to the power section failing (like power transformers going out). Likely, the built in limiter is the problem.
I hope this helps!
-mike
(development engineer)
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
50 people viewed this question
 Grubhead
Grubhead
