Question about Sony PlayStation Portable (PSP) Console
PSP is frozen....
Psp froze and everything we have tried, (remove battery, plug into charger) has not worked.
  • rajesh16au Jun 08, 2008
    PSP freezes even without UMD when you keep flicking through the PSP menu options when you start. It also freezes when you browse image from memory stick.
    I had opened PSP completely and have cleaned all borad and contacts with ISO PROPYL alcohol. problem still remaind same.
    Regards,
    Rajesh
    rajesh16au@gmail.com
    Problem Solver:
  • 4 Answers
Go to this site http://wwww.fxya.com/support/t839832_psp_slowed_down, if the game could not be started go to menu of your psp and press again the select change umd iso mode to m33.
Posted on Oct 07, 2008
Bricked?>??
Posted on May 17, 2008
  • 84 Answers
It sounds like it is bricked
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
My psp when I open the psp theres nothing but sometimes when I open it without battery and put the charger and it shows up then i put the battery it works so sometimes I do not close the psp
Lets try that again...
I take it by "open up" you mean when you power on your psp yes?
by "there's nothing"do you mean blank screen? no power light? no loading?
From what i make of it your psp is not loading when the battery is inserted only, it will load when the battery is removed and the charger is plugged in only. After it has loaded you are able to insert the battery and remove the charger and you try to keep your psp running continuously so you don't need to take the battery out.
If I am correct in my interpretation you have a faulty battery that should be replaced.
Jun 01, 2010 | Sony PSP (Piano Black)
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Psp dont charge
i think its one of 3 things
1. the internal power connector
2. part abxy and power switch circuit board
3. bad battery
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Charger?
As far as linloo goes the connector (the yellow part on your psp) sounds like it's going bad or it is bad. You can find it on the net for repair and should cost more than $4-7.
k_cullen95
Do you have access to another psp? Okay so you say you have tried plugging it into different outlets. It could be the adapter (charger might be bad) But the only way to test this is to put your charger on another psp to see if it charges. And vise versa with the other person charger on your psp.
And just in case you may want to check the battery and or the conector. By doing the same method I just said.
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Screen frozen with
Mr. Daniel you can solve the problem of your granddaughter's psp by removing the battery of her psp and it will shutdown put the baattery back in and you can restart her psp....
hope it works...
Aug 20, 2008 | Sony PlayStation Portable (PSP) Console
Psp doesn't want to turn on
The polarity of the charger you used is wrong or the wrong voltage, and has messed up the programming n the battery.  You may be lucky if you get a new battery and use the Right charger, It might fix it.  Sony put a battery in the PSP that has a memory chip in it, and I think it will automatically disconnect if the wrong vooltage hits it, or wrong polarity. be warned that I have seen where someone got a new battery and it did not solve the problem. If this happens to you Contact Sony at the following number.
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
Sep 28, 2007 | Sony PlayStation Portable (PSP) Console
Psp won't turn on
Try to charge your PSP with your son's PSP charger and your problem should be solved if so your PSP charger is faulty.
Aug 31, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
102 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
