Question about Protron PD-DVR100 DVD Recorder
SETUP/GENERAL I'M STUCK IN "PROGRESSIVE SCAN" AND i NEED TO GET BACK TO INTERLACE. I CAN PLAY MY PILATES DVD.
  • 1zippy1 Jul 13, 2008
    selected progressive scan in set up, then lost total picture. I shut off the player and turned it back on then press and hold down th p-scan button lower left on remote. it should go back to interlaced and your picture will come back. good luck!
  • 667 Answers
Hi shadow - I could tell you how to do it but I'd probably just get you confused trying to follow my directions. I believe it's easier to look at the manual when possible and see any pictures. Below is a link for your manual. To download it just scroll down and enter the 5 letters in the box. I think you may want page 34. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=8f0fdae37b6e0e77cf62d832c3dc4efe&q=SpectronIQ+PD-DVR+100
Jeff
Posted on May 16, 2008
How do you get higher than 480p resolution on playback?
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Jan 25, 2014 | Philips Magnavox MWD7006 DVD Player
Stuck on progressive scan
This is a common issue with this brand of player. While the unit is on, and without any discs inserted, press and hold STOP button on the front panel (not the remote) for 10 seconds, then release. This should turn the progressive scan function off and revert the video output of the player back to normal interlace.
Zenith, Samsung, Magnavox, and Goldstar DVD players are notorious for progressive scan headaches, but it's easy to correct.
Apr 16, 2011 | Zenith Televison & Video
HOW DO I GET MY DVD OFF PROGRESSIVE SCAN
You do either of the following; refer to your instruction manual (if you still have it) and look for general output settings to turn off progressive scan, or you can try something much simpler.
On the front of the unit, without a disc inserted, and the drive selected as DVD, press and hold STOP button for 10 seconds (on the unit, not the remote), then release. This may revert progressive scan back to normal interlace for your TV, and thus turn progressive off.
This trick works for Goldstar, Samsung, some LG, Magnavox, and Zenith DVD players. Give it a try before referring to the manual.
Apr 13, 2011 | JVC DR-MV150B DVD Recorder/VCR
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
Denon dvd player is in progressive scan-need it in interlace
used single composite video plug to get back to setup.all is good again
Dec 25, 2008 | Denon Televison & Video
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
No picture
I did same thing and I got it back by pushing p-scan button.
Jan 14, 2008 | Protron PD-DVR100 DVD Recorder
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
Protron PD-DVR100 DVD Recorder Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
