How do i get rid of the over stack flow line: 0 on my desktop
  • 2,229 Answers
Visit this site and follow the directions:
http://support.microsoft.com/kb/923737
Posted on Sep 14, 2010
Stack over flow at line 195
This comes directly from Microsoft web page.
"If you try to open multiple modal dialog boxes in either of the following programs, you may receive a stack overflow error message:
  • Microsoft Internet Explorer 6 on a Microsoft Windows Server 2003-based computer
  • The Mshta.exe HTML program"
They say they have a hotfix so go to this page.
Jan 12, 2014 | Microsoft XP Computers & Internet
Stack line overflow at line 42
Stack overflow is an internal command that tells a program or data to link up with other code. The software developer who wrote the software program was directing the flow, like traffic on the highway; and somehow the path did not make a proper move in one direction or the other. This linkage is common to an Operating System. Windows 8.1 for example has a better flow than the previous Windows versions.
Dec 21, 2013 | Microsoft Windows Vista Home Premium with...
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
A message just "popped up"
It has to do with memory. When you make requests of your computer programs it puts those requests in a stack (or pile) and then works on them in a predefined order. There's a certain amount of memory reserved for the stack and when you exceed it you get a stack overflow error. These errors usually either kill the request or result in a program crash.
Jan 28, 2011 | Microsoft Computers & Internet
Computer pop up
IE: stack overflow at line: 0 Today, I noticed the following issue (IE only, of course). Running a page that does some comet (via “XHR GET” for long-polling), I got the following warning: “stack overflow at line: 0′ and the application stopped working…
I did some google-searches and found some “hints” that said I should disable my third-party tools for IE etc. That sounds strange…
In fact the problem was the odd cache behavior of the IE. The XML (from the “long-polling servlet”) was cached and its JS was executed; also the application itself started the polling too, so I (no IE) ran into this odd issue…
Changing the server-side code – that is responsible to render the XML – to have no cache rules (e.g.”Cache-Control”:”no-cache”) did the trick. It worked again. Of course, on your “comet output” you potentially don’t want cache to be present…
So fixing the cache solved the issue. There was no need to disable Norton or any other third-party tool… icon_smile.gif
Mar 28, 2010 | Microsoft Windows XP Home Edition
Need to reset or eliminate 2nd time
Note: Wrong procedure will affect your computer startup settings so be careful in doing this steps.
Follow this steps:
  1. Click Start menu from your desktop screen
  2. Choose and right click on My Computer
  3. Choose Properties
  4. Go to Advanced tab
  5. Click on Settings button under Startup and Recovery
  6. In Startup and Recovery window click Edit button
The notepad boot.ini file looks like this one
http://lh4.ggpht.com/ciprahkapa/RwYQCqUnrQI/AAAAAAAAAIg/q9E-gZ6W_L8/change%5B3%5D.jpg
Your default operating system is:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
as shown in:
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
You'll see the second line containing
multi(1)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional"
or other operating system like Windows Vista
You have to delete this second line from multi..... to the end of the line that contain a second boot of your windows
Then click File Menu > Save
Close the notepad file (boot.ini)
Also refer to this information for some explanations to understand more about boot.ini file
http://vlaurie.com/computers2/Articles/bootini.htm
Jan 16, 2010 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
