FixYa.com
Tags:
Brother MFC-420CN All-In-One InkJet Printer
Brother all in one MFC
posted by DaChamp8 on May 15, 2008
Hi Guru,
Just received my new fax number and it is on the same home phone line.
When I initially set up the machine, I put in my home number and now need to change the number to my new one just given to me. I can't seem to do it and have tried everything in the menu. How do I input my new fax number? Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 20, 2008
Not Rated (0)
nealgbrown
Rank:Wiz Wiz
Rating: 84%, 47 votes
According to the user manual, which can be obtained at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
if you don't have one handy, the steps to set your fax machine's number is on page 42. The steps to take are:
Setting the Station ID
You should store your name or company name and fax number so
they print on all fax pages you send.
1 Press Menu/Set, 0, 3.
2 Enter your fax number
(up to 20 digits).
Press Menu/Set.
3 Use the dial pad to enter your name (up to 20 characters).
(See Entering Text on page B-11).
Press Menu/Set.
4 Press Stop/Exit.
You cannot enter a hyphen in the fax number. To enter a space
press once between numbers.
If the Station ID has already been programmed, the LCD will ask
you to press 1 to make a change or 2 to exit without changing.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Text on paper comes out fuzzy
The text on the printed paper... Answer This...
fax doesnt work
fax doesnt work Answer This...
My Printer EPSON TM-U220 does...
Mi Epson tm-u220 does not... Answer This...
Printing anything off of the...
I am not able to print off of... Answer This...
Will not print
LCD says Unable to print see... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
