Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
How do you get the beater brush to start rotating, the dyson was just cleaned and the beater brush won't rotate
  • 377 Answers
Sounds like the rubber drive band has not been replaced properly to drive the brush and/or the brush was not properly cleaned. You can find the manual here:
http://dl.owneriq.net/4/4d79dca8-65d8-4c46-a58a-a2fef1f89635.pdf
Posted on Sep 14, 2010
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brushes stop rotating on rugs after a few seconds then button has to be pressed to start rotating again but keeps cutting out
Not sure this is your foolproof solution to the problem, but you might give it a try to see if it solves your problem.
When the beater brush starts to bind up due to debris it retards the action of the cleaner, sometimes to the point of the belt breaking.
Remove the beater brush as if you were going to change the belt. Remove all debris and clean as best you can. Pay attention to the end pieces on each end of the beater brush. They will can clogged to the point to stopping the brush from rotating. Add some WD40 to the clips at the end of the beater brush and work in by twisting the clips while holding the beater brush. Once it seems to be free, reassemble and be sure the belt is on properly, you might want to consider replacing the belt.
If you find this solution to be of help I would appreciate a Thumbs Up. Good luck and be well. Paul
Oct 06, 2010 | Dyson Vacuums
Hi! I have a Dyson ball and I am hearing squeaking sound. The roller doesn't seem to be absorbing most of the dust. what do I do?
Two things you should check:
1- Be sure the belt that drives the beater brush is snug.
2- Good idea to remove the beater brush and clean as best you can. At each end of the brush there are two hard rubber retainers that hold the brush in the housing. Add some WD40 between these retainers and the brush, rotate to be sure the WD40 is worked in so that the retainers move freely around the brush. Sparingly, add a bit of WD40 to any part (wheels) that contact the floor when the unit is in use.
If you find this solution to be of help, I would appreciate a Thumbs Up. Thank you. Paul
Oct 06, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Cannot get the brush to rotate when vacuuming
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly.
Sep 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater head makes loud noise on 'carpet' mode
Possibly a belt problem, but more than likely a brushroll problem.
The bearings are cheap and nasty, and are prone to siezing.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 29, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush rotates on my dyson slim but there is no suction. though there is suction from the hose... has anyone any ideas????
Un-plug the machine first. Turn the unit over and remove the bottom plate. Check for and remove any debris in, around, or behind the beater bar assembly. While you're in there, look at the beater bar ends where the bearings sit. and clean any debris, hair, etc, from those areas as well.
May 17, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Beater brush does not rotate
i had the same problem, but was able to fix it by opening the brush compartment and cleaning the brushes, then separating the brush head from the body of the vacuum and hitting the reset button at the top of the brush compartment (per dyson online instructions). Works perfectly now.
May 04, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson 18 slim the rotating brush bar will not rotate. Was working fine until I got the edge of a tablecloth caught in the brush, pulled it out ok but now the brush will not rotate fast, but will rotate by...
If the DC18 has a proteted belt then it will have to be replaced by a Dyson engineer or repairer. If the cleaner has a removable sole plate where the beater bar is then remove it and replace the belt - sounds like the belt has snapped and needs to be replaced. if your DC18 is still relatively new it should still be under guarantee.
Mar 25, 2009 | Dyson DC18 all floors Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
87 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
