Question about Weller Welding Tools
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
  • 4,340 Answers
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Posted on Oct 20, 2010
What is the proper output voltage going into the solder tip?
The voltage is nearly unreadable it is so low, but the current is quite high. If the tip won't heat, loosen the tip nuts and re-tighten.
Dec 12, 2010 | Weller 8200 Soldering Gun
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
The weller 8200n does notheat up
Make sure the tip is tightened fully, use a 5/16 wrench to snug it down.
Feb 28, 2010 | Weller 8200 Soldering Gun
My weller wsd130 solder won't work.
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.
Feb 04, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
TRYING TO GET SOMEONE TO REPAIR A WELLER SOLDERING GUN
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.This can cause the gun to over heat.
Dec 09, 2009 | Weller Welding Tools
The light comes on. It does not heat up. The gun worked a day ago, what's up?
The tip is probably dirty. Loosen up the screws on the side and pull the tip out. Clean them off by scraping them with a knife or with sandpaper. Put it back in and tighten the screws. It should work then. Sometimes it's just that the screws are loose.
Nov 29, 2009 | Weller 8200 Soldering Gun
Weller 8200 100/140W replacement light bulb?
The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf
Sep 14, 2009 | Weller 8200 Soldering Gun
Weller 8200 does not heat
loosen nuts that hold tip and retighten,it'll heat if xfmrs good
Jul 13, 2009 | Weller 8200 Soldering Gun
Welding Tools Logo
692 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
