Question about Toshiba e-studio 455 Copier
I have Toshiba photocopier, Studio 455. i want to print one page label paper. Should i use a bypass, which i tried but did not work. Tell me how.
  • 1,110 Answers
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
Posted on Sep 14, 2010
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
I have a Toshiba studio 232 photocopier, every time I use it, it says "ADD PAPER" when I select the tray I will be using, so I couldn't use those paper trays... I have no choice but to use the bypass tray...
Might the lift motor is not working, or try to hold the tray pressing in and wait, you can hear the lift motor sounds and stops if not your lift motor assembly is failed it can be repaired.
May 21, 2014 | Toshiba e-Studio 232 Black and White...
Printer hangs
check touch screen job status. this particular user might not have the setting configured properly on his pc and affected all job queue due to paper size not avail in any drawer or bypass paper needed.
to release the rest of the job queue, just delete the job pn the touch screen. u can see the delete button on the touch screen when u press job status
Mar 20, 2014 | Toshiba e-studio 455 Copier
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
If i have already printed off a paper that i wanted, and now i want to put something on the back of that paper, how would i do that using my printer
what I do is put the paper back in the printer again to be used with the info on the page facing up that way when it feed the paper back thru mine prints on the other side of the paper
Aug 11, 2011 | Toshiba e-studio 455 Copier
There is a display message that comes up when you press the job status button that is flashing "Check the direction or the size of the paper on the bypass tray and press start", we are not trying...
try to format its HDD :
turn it off..
hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again or enter . Wait for it to say "please reboot the machine", turn it off and back on. Hopefully this will work..
Jul 05, 2011 | Toshiba e-studio 455 Copier
Setup photocopier wirelessly
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
Jun 03, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba Studio 200 CP
Use the manual paper feeder, and set the paper type labels
Jun 18, 2008 | Toshiba e-Studio 200 All-In-One Laser...
Toshiba e-studio 455 Copier Logo
535 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
