Question about Quinny Buzz Jogger
The front wheel on my quinny buzz 3 hardly moves and makes steering the pram very difficult. Especially on tiled floors, such as shopping centres. The wheel isn't locked, so it's on the swivel wheel function but it is still very hard to steer.
  • 419 Answers
The best thing to do is to remove the front wheel (depress the black buttons either side of the front axle and pull!) then completely clean the wheel assembly in warm water and a SMALL amount of gentle detergent, then dry completely, apply a small amount of vaseline or similar, then replace. This should help.
Posted on Sep 15, 2010
  • Phil Walker Nov 21, 2011
    Helps enormously if you separate the wheel assembly swivel shaft from the bent tube that holds it on to the buggy (released from the buggy by pressing the two balck buttons). If you look in the side of the bent tube there is hole. If you rotate the wheel swivel shaft inside the tube whilst looking through this hole a button will appear. Press the button with a small screwdriver and the swivel shaft with wheels attached will fall out. It will probably be coated with old grease + dirt making a sort of sticky glue. The inside of the bent tube will probably be even worse. Clean this all off with kitchen roll soaked in white spirit or WD40. Then grease the inside of the tube and the outside of the swivel shaft with vaseline or, better, wheel bearing grease. Make sure the button moves freely and pokes through the hole in the shaft correctly and reinsert the swivel shaft in the tube. Fit back onto the buggy. It should now work like new!
Quinny buzz with brokin hydraulics
mine's been broken for 3 years.. did that black metal peiece inside break ?
Jun 04, 2010 | Quinny Buzz Three Wheel Stroller
How do you fold a quinny buzz?the instructions dont help!
position the pram so the front wheel is facing you,put your feet either side of the wheel to stop the wheels moving
push the two grey button that are on either side and as you push the buttons pull down the frame towards you.
hope this helps.
Mar 07, 2010 | Quinny Buzz Jogger
Unable to fold and front wheel keeps sticking
Hi Kelly,
Over the years we have seen customers having trouble folding the Buzz. Mostly it's a combination of factors that make a Buzz a bit stiff.
Most important is that the main silver central tube must be clean and preferrably lightly lubricated. (Put some WD40 on with a rag.)
The second point of attention is the grey release knobs: Remove (blow out) any sand or debris and spray in some WD40. Especially the knob on the left that is slide-push needs this attention. (Left-right viewed in the driving direction.)
These grey knobs have to be pushed firmly to properly fold the chassis. (The left one is first-slide-then-push.) When it folds and gives a loud 'clack' you didn't push them in far enough. We know from experience that this sometimes remains difficult for some customers.
Later revisions of the Buzz have slightly larger buttons that are somewhat easier to operate.
Your front wheel probably needs some care. At the side of the black plastic front 'fork' that holds the wheel you will find a small hole. Rotate the front wheel until you see a small button come by. Push it with a pointed object. (A small screwdriver will do)
You can now remove the front wheel from the black front fork. Clean the internals and lubricate, preferrably with a teflon loaded grease or teflon spray. (Spray is less durable than grease)
This will take care of your steering problems.
Alternatively you can have a look at the Quinny Buzz All Terrain wheels. It's a sturdy drop-in replacement for the original wheel:
http://www.babycare.nl/quinny-buzz-all-terrain-voorwiel-p-1819.html
Please contact us through the contact form on our website if you need further assistance.
www.Babycare.nl
Erwin de Raad
Jun 23, 2009 | Quinny Buzz Jogger
Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
Mar 11, 2009 | Quinny Buzz Three Wheel Stroller
Front wheel wont roll on smooth floor !!
Hi
I have had this problem as well but what you need to do is take the front wheel off by pushing in the 2 black buttons. Then when you do this there is a hole near the bottom, what you need to do is turn the wheel until you can see the pin inside then use something thin to puch it in this will release the wheel. You need to clean the inside of this and then spray with silicon spray NOT WD40 as that will make it worse.
In the instructions it does tell you to make sure you keep them oiled but it does not tell you how to do it.
Once you have done this it will work like new again. I took mine on the beach and had to clean the sand out and i also think that from where we have had all this snow the grit has not helped either.
I hope this works for you as it has for me, i love my Quinny and would not change it for the world but i was starting to hate it before i done this
Soph
Feb 22, 2009 | Quinny Buzz Jogger
Quinny buzz 3 2008
if you phone dorel they will talk you through what to do, i sent them my frame Quite cheap to post, i used make shift box and removed the wheels etc, and they fixed it and posted it back to me..problem solved phone number is 01842763281
Aug 19, 2008 | Quinny Buzz Jogger
Qyinny buzz 4 cant fit the shopping net under pram. it has velcro and a square ish open metal piece
If you take the front wheel off the square metal clip slots into the frame.
Apr 22, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
893 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
