Question about Sharp AL 1631 Copier
The machine acts like it's making a copy but nothing comes out. had trouble before but it corrected itself. not this time.
  • 1,110 Answers
Is the machine just running? Either after turning it on or pressing the copy button? This usually means that the toner is very low and the machine is trying to add toner which it must do before it will actually make the copy. Let it run for a few minutes and see if the toner light comes on. This will look like a small stack of 6 dots. If this light comes on you will need to replace the toner cartridge.
Posted on Sep 14, 2010
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
I have photo copy machine modle konicaminolta the screen show trouble code 3423 how can fix
1.Turn OFF the main power switch.2. Turn main power switch ON while pressing the Utility/Counter key. (Control Panel ON/OFF must be ON)
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
IF THE CODE COMES BACK DO NOT !!!!! RESET AGAIN THE FUSER IS THE PROBLEM IT CAN CATCH ON FIRE AND THAT WILL RUIN A PERFECTLY GOOD DAY GET A TECH OUT TO LOOK AT THE FUSER
Dec 27, 2012 | Konica Minolta Minolta Bizhub 223 Copy...
My mom has the 8050 and the bottom thread when she sews is knotting. She did the trouble shooting from the book and no change. She has only had the machine for four months. Wondering if you have any...
have you try using a different bobbin & thread. make sure the bobbin wound & is inserted correctly
check to make sure the top thread has not come off the thread take up lever
has a new needle been put in?
make sure there are no burrs on the needle plate or bobbin itself or bobbin case
let me know if any of these suggestions help machine work correctly or not
Aug 26, 2011 | Janome Sewing Machines
I am haveing trouble with the top thread not sewing, the bottum tread come to the top; I have ajusted the theard tinshen , nothing works. glenda@netzero.com
you might check your needle to see if it's bent-roll on a flat surface to see if it roll correctly
if the needle makes a popping sound going into the fabric then the needle is blunt
check to see if the top thread is catching on the spool pin or the spool of thread it's self, where the little notch is at the holds the thread
I've had the thread to come off the thread take up lever several times
let me know if this helps you
Sep 23, 2010 | Brother PE-150V Computerized Sewing...
Acts like it is copying but nothing comes on paper.
your cartridge are empty or dry
try cleaning them from maintenance menu
or refill it by this method
http://www.youtube.com/watch?v=MPi2GqJg5QM
Apr 27, 2010 | HP OfficeJet J4580 All-In-One Laser...
Wont spin, stops and clothes soaked. did the trouble shooting and still nothing..;..
Here are some reasons why the washer would act up:
Too many clothes in the washer. Sand and sediment in water level tube. Slow drain pipe. Plugged pump. Washer onboard intel will monitor the water level of the tub through the pressure tube on the water level switch and make a determination if the water was pumped out in a set amount of time. If intel does not get a confirmation then the washer will shut down for fear of a flooding condition. To correct this you must open the drain, straighten the hose, unplug the pump, whatever it takes for the pump to empty the water at the pre determined time set for the on board intel board. If all those things are good and still no joy then computer board replacement might be in order.
Dec 25, 2009 | GE WCVH6260FWW
Paper goes in but does not come out
I would suggest opening the printer up and taking a good look inside to see if there is any kind of obstruction. Jus a tiny piece of torn paper is enough to cause the whole feed system to jam up. Another thing to look for it that if the paper it getting pulled in straight. If it goes crooked on its way in, your paper feed itself might be the root cause.
May 06, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Cannot copy Double-sided
Q1- What make and model of copier are you using? Q2- Which document feeder are you using?
Sep 26, 2007 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
