Question about Sony KP-65WV700 65" Rear Projection HDTV
Hello my sony kp-65wv700 tv will turn on for just a few second then it turns off. Then would not come on for at least a few minutes. Thanks Mark 770-318-9925
  • dorry707 Sep 14, 2010
    I have a Sony kp65wv700 turns on and then comes off immediately, prior to this there was a green line across the tv when watching even after it was turn off almost a wave line (rainbow ), I just notice now that it would not even come on now.
    Mark
    770-318-9925
  • Sony Master
  • 5,807 Answers
Here are some
Troubleshooting Tip:
if a failure occurs in the 5V Standby Power Supply the unit will
not even attempt to turn ON.
If this condition occurs,
check the following components:
1) FH501
2) 13V at IC501 Input Pin (I).
If missing, suspect T502, D503 and/or C507.
3) 5V at IC501 Output Pin (O).
If missing, suspect a defective IC501.
4) NOTE: Q503 is used as a current source for the AC relay
(RY6501).
If the collector/emitter junction of
Q503 becomes an Open circuit,
the set will still turn ON (using voltage through D509) and
function properly with sufficient AC power input.
If the AC power input is weak (Low Voltage ~90VAC, the unit
will have difficulty turning ON
without Q503 functioning properly.
5 ) If the 200V line on the CRT Board equals the voltage
value of the Power Supply (135V ) then your Flyback
is not oscillating
Posted on Sep 14, 2010
  • 4 more comments
  • Rommel Cana
    Rommel Cana Sep 15, 2010
    Could the green line be slanted upward to the right or just plainly
    a horizontal line?
    Whichever the case, you might need to hang freely the CRT Board
    to determine if power tries to go on, and not turning Off
    while troubleshooting
    the unit
  • Rommel Cana
    You should also be having a sound , even all the
    CRT Boards are hanging , only if there
    are 200V on the 200V line.
  • Rommel Cana
    sample image of a CRT Boards:
  • Rommel Cana
    Hanging meaning Unconnected to the CRT s
  • Rommel Cana
    If you can hear sound ( with a source connected like Ant or AV In )
    on your speakers,
    then you just have troubleshooted a large percentage on
    electronic troubleshooting.
  • Rommel Cana
    • And when it is hanging you can probe your Multimeter
    How to use a multimeter
    here ( 200V line )
    sample image on Red CRT Board:
  • Sony Master
  • 11,800 Answers
You have a faulty part either in the power source or the high tension module. To identify the faulty part the tv must be opened and tested - this is a job for someone qualified in that, so call a repairman, there's nothing more you can do.
  • Azrael SRL Sep 14, 2010
    A green line is caused by the fact that the green tube in no longer suppressed when shut down -and later this has spread to all 3 tubes. This is a major malfunction in the high tension and the final video boards - the ones that power and control the tubes (the power source is probably just fine, it was shutting itself down to protect against the overload caused by the failed parts). Start checking the voltages at the tubes especially the G2 one - and that of the cathodes.
I HAVE A KP-65WV700 SONY PROJECTOR. WHEN I TURN IT ON, I SEE THE IMAGE BUT AFTER 1 OR 2 MINUTES THE SCREEN GETS COMPLETELY RED.
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Mar 15, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Kp-65wv700
You need to adjust Green screen drive control your green tube could be shorting out.
Sep 14, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
KP65wv600
This unit is notorius for having shorted or int. shorted crts. Not good news ans this is very expensive and the crts are no longer available and can only be rebuilt by send to Video Display company.
Feb 07, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-65WV700 65" Rear Projection HDTV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
