Question about Pioneer AVH-P6600DVD Car DVD Player
Avhp-6600 ok i have a pioneer avhp-6600 and it was working just great until today when i press the open/close button nothing happens my screen will not come out of my machine the radio and the cds play but the screen will not come out
  • Kishman Jul 12, 2008
    Having the same problem.
    It worked fine the night before... then I tried it the next day, and nothing... it beeps but it doesn't come out, I don't hear any noise coming from the motor in it. I only can think of 3 random causes;
    The heat (It got up to 35 degrees Celsius in the past few days)
    The Bass (Got 2 Kicker L7's... and they pound... so may shake some screws loose)
    or the motor just burned out...
    I'm gunna switch it with another deck for now and try to send this one out for repairs.
    I'll keep this posted if I found a solution...
  • sundial99 Aug 01, 2008
    Yah, I've run into the same issue. It will be working fine...then quit opening for months...then one day randomly open again. I have no idea why but hope someone has a suggestion.
I have the same problem. Was installing this morning and was opening/closing fine then nothing. Tried the reset button and still dosent work. Also i have no sound even though the sound worked when i took it out of another truck anout a month ago
Posted on Jul 16, 2009
You have to wire green to ground in order to have your screen open while driving, otherwise you have to pull the ebrake and it will open. Its made that way so that you dont drive with the screen open.
Posted on Nov 12, 2008
I have reset the machine, by press reset button. The Screen is out ,but when i touch the screen I can not change TV, CD, or tuner.
Posted on Oct 24, 2008
I have the same problem with my unit. there is a way to reset the screen so it starts to come out again as i have done it 3 times before. i forgot the exact method but it involves the "rear" "band" and "reset" buttons. i found this out through calling pioneer canada tech support and i will call them again on monday when they open.
Posted on Aug 17, 2008
Pioneer CJ-V51 CD jukebox error 1
1 Open top door (display shows OPEN)
2 Press and hold SERVICE button until beep (display shows P5)
3 Press and hold CLEAR button until beep (approx 25 seconds)
4 Press and hold SERVICE button until beep
5 Close top door
Apr 06, 2012 | Pioneer AVH-P4900 Car Video Player
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
Purchased region free pet7402a/37 in US, I am in europe and it plays "wrong region", any suggestions?
I just unlock mine PD7012/37 today, I think you can use de same sequence:
1- Power on without dvd;
2- In SKIP button, right side of SETUP, press "RIGHT", "LEFT", "RIGHT", "LEFT", "RIGHT", "RIGHT", "LET";
3- Will appear a menu, go to REGION using "UP" navigate button, and press OK, select "TEST 0" using navigate button and press OK.
4- Press STOP;
5- Enjoy.
Apr 12, 2011 | Philips PET7402A/37 Player
Have the Samsung BDP1590. The screen only says CLOSE and will not do anything else. Tried the reset instructions but nothing happens. The DVD player is less then a year old. Can someone help me out.
I had this problem when trying to play Avatar and my player locked up. I'll assume you have a disk inside when this happens.
Try pressing the power button to turn it off, then turn it back on again but as it starts press the Open/Close button - you may have to do it twice because at the first press my BDP1500 says "CLOSE" then a second quick press will show "OPEN". Take the disk out, then try another disk. If it's a problem with trying to play a recent disk you should be ok until you try to play it again. Read up on updating your firmware, etc. Good luck.
Sep 18, 2010 | Samsung BD-P1500 Blu-Ray Player
Nokia 6600 keypad malfunction
TRY THE MANUAL FOUR BUTTON PRESS FORMAT THAT IS SWITCH OFF YOUR FONE, THEN PRESS DOWN *3 THE GREEN BUTTON AND SWITCH ALTOGETHER AT ONCE AND HOLD DOWN TILL SCREEN DISPLAY FORMATTING
Aug 24, 2009 | Nokia 6600
Does'nt open
When you download games from internet ,it might be possible that it contains virus and may cause your mobile behave unexpactedly .so now it seems that you are unable to open your menu.........
Soluton :
Try flasing the mobile or format the mobile so that you can get the factory settings
WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
OR YOU CAN USE
*#7370# FOR MASTER RESET
GOOD LUCK !
May 29, 2008 | Nokia 6600
Nokia n95
You could try this, it worked on my N95. But not on my mates. So it's up to you, this will reset the phone, or not, but whichever way it won't damage it.
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Mar 11, 2008 | Nokia N95 Cellular Phone
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
Jan 19, 2008 | Pioneer HTZ-77DV System
6600 camera temp over load
try reformatting your fon... try this... press together call, *, 3 then switch it on and hold all keys until you see formatting on the screen...
remove batt and do it again if formatting doesnt display on screen...
if still nothing happens after formatting then probably you have a prob in your bluetooth module...
Oct 28, 2007 | Nokia 6600
Nothing happens when i open or close it
it usually happen when you accindetally dropped it... thiers a little thing which i called it a little magnet...this magnet serve as your door man...when you go out he will open it for you and if go in he still do same things.. well i mean check this little thing .. if he still there in his position...replce it when it gone..
Nov 21, 2006 | Samsung SPH-a620/VGA1000
Pioneer AVH-P6600DVD Car DVD Player Logo
361 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
