Question about Kenmore 74602 Gas Dryer
Dryer not heating up
I have a whirlpool gas dryer #lgr7646eq2.
it just stopped heating up one day it will run for hours with no heat.
what do you think is wrong?
thanks
joe wagner the burner will will not come on. I replaced the igitor.
  • Anonymous May 16, 2008
    I have a Kenmore Model 76902 gas dryer that tumbles but does not heat. Opened it up and when started igniter does not glow. Took igniter out and applied 120V to it and it glowes fine. Can someone help. What would make it so the igniter does not glow when machine is turned on yet the igniter has coninuity and heats up fine independently?
    please e-mail me at hdriver@nasonconstruction.com
    many thanks,
    Henry
    President:
  • 1,314 Answers
Replace the two selniods on the safty valves
Posted on May 16, 2008
My Gas whirlpool dryer model # LGR7646EQ2 wil not heat up.
Sounds like a thermal fuse. Follow link to part # and more details. Best of luck!
Whirlpool Thermal Fuse
Apr 07, 2012 | Whirlpool Dryers
Dryer has never had a single problem until the other day the "heat" just stopped. Dryer still has power and runs. Help... Rob charleston,SC
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Dryers
Whirlpool lgr7646eq2 dryer is not heating up. I checked the valve its open. any suggestions?
dependind on how old of model your hsi might need to be replaced (as valve im assuming its a gas dryer)
Sep 13, 2010 | Whirlpool LGR7646E Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
My whirlpool dryer LGR7646EQ2 dryer heats but will not shut off
will it shut off on timed dry?
if it does the sensor dry board or sensor are bad
if not the timer is
Jun 08, 2010 | Whirlpool LGR7646E Dryer
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool Lgr7646eq2 Dryer
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Apr 06, 2008 | Whirlpool LGR7646E Dryer
Kenmore 74602 Gas Dryer Logo
157 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
